6.4 died, wont start... ( I thought it gelled, mechanic thinks HPFP ) - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-16-2014, 11:01 AM Thread Starter
Hey all I have a 08 6.4 that is deleted and it has 177k on the ticker. A few days ago I did not add any additive until right before I drove the truck and temps were around -10. I had a full tank of fuel. I started the truck and let it warm up for a good 15 min then drove about 5 miles and it acted totally fine, then it lost power (going 60 put pedal down more noticed it wouldn't accelerate). It then died, and I was able to start it again and it ran horribly rough and I made it about 300 yards and it died again. It wouldn't start after that. I assumed it gelled.
So we checked the filter under the hood and it didn't appear to be gelled. We then towed it home and let it thaw out in 70* temps with a salamander heater blowing under it for a good 5 hours. Wont start, just cranks. Eventually it was to the point where it tried to fire a few times but just barely.
So we took it to our diesel mechanic and he does not think it gelled and he thinks it is the HPFP, but he still does not know if that is it or not. He changed both filters... He said it will not build pressure.
The codes I got on my mini maxx were: p0087, p2291, u3f00, u3f22, p006b, and p0196.
Does anyone have any ideas what it could be or do you think it is the HPFP? ( I sure hope not... don't want to dump thousands into a truck with 177k ) I am now afraid the truck is going to be a "ticking time bomb" and I plan on selling it once it is fixed and getting a 6.7 and just leaving it stock so I have a warrantee.
One other thing to note was I bought my fuel the night before this happened from Murphy USA (Walmart) and I am wondering if ****ty fuel didn't cause this because I never buy fuel there. I was down to 50mi to empty when I filled up.
Parker22 is offline
post #2 of 6 Old 02-16-2014, 11:28 AM
ZMANN's Avatar
Quoted: 1784 Post(s)
the gel issue should be a non issue at this point after heating etc IMHO
We Miss you Ronnie
ZMANN is offline
post #3 of 6 Old 02-16-2014, 11:31 AM
ZMANN's Avatar
can u verify
u3f00, u3f22, p006b
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 02-16-2014, 11:42 AM Thread Starter
Originally Posted by ZMANN View Post
can u verify ?
I have absolutely no idea what those codes are. Couldn't find them anywhere. Mini Maxx says unknown DTC next to all three.
Parker22 is offline
post #5 of 6 Old 02-20-2014, 11:51 AM
U codes and network codes, there's a problem with the computer communicating with something. I'm not at work so I can't look them up but that shouldn't prevent it from starting. If you did gel you could of taken out the lift pump, the one on the frame rail, you should get 5 psi at the schrader on the fuel cooler
Chicagostroker14 is offline
post #6 of 6 Old 02-22-2014, 07:55 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
P0087 OHH BOY AND 2291 OUCH!! I think you may be lifting your cab and replacing your high pressure pump and some other things. If any water goes through them it destroys the pump leaving little metal chips to go through the rest of the system these chips sometime hold the valves open in the hpfp causing a crank no start. One way to tell is take off valve cover and remove the steel tube to either no 1 injector or no 2 injector, catch the fuel in a black cap for break cleaner or something. shine a light in it and see if you see glitter. If you do well your in for a ride!! New pump, new rails, new injectors, and flushing entire system. Iv done so many im sick of them well not really sick of them because I love doing them.
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
