Coolant cap info. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-15-2014, 05:29 PM Thread Starter
CowboyCody's Avatar
Quoted: 3 Post(s)
Coolant cap info.
Just thought I would post my experience for the benefit of others. I recently did the head gaskets and ARP head studs on my truck. While I was in there I found that my heads were cracked so I ended up putting new heads on also. After I got it put together I was still puking coolant when I got in a long pass pulling my 5th wheel camper. I was not happy! and assumed the worst. That a mistake had been made during assembly. Just for good measure I put a new degas bottle cap(or whatever the proper term is) from Ford on it and hoped for the best. Next pass it pushed some coolant out again. Not long after this I was doing some research on the subject and found the video Powerstroke Help did on the cap issues with Ford caps. I then set out to find a Stant cap for my truck, I stopped at Napa and they did not have a Stant cap. Just the napa Balkamp brand I thought for $5 I would try it. I pulled it out of the box and noticed the spring was bigger and it didn't click when I put it on, I could just crank it down tight. Ever since I have not lost any coolant, even on the long pull on I5 coming into LA. I think the moral of the story is to buy an aftermarket cap that doesn't click when you put it on.
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2000 Excursion Limited, S&B intake, GTP 38R turbo, Billet Transmission upgrades.
CowboyCody is offline
The Following User Says Thank You to CowboyCody For This Useful Post:
kinnisoj (02-15-2014)
post #2 of 2 Old 02-15-2014, 05:32 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Good deal you didn't tear back into the motor for nothing....but now I gotta walk out in the dark and see if my cap clicks..
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
