Updated radiator hose questions - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-04-2014, 07:36 AM Thread Starter
I know that Ford updated the 6.4 radiator hoses to be double O-rings in lieu of singles some time back. Were ALL THREE hoses updated ? I know in confidence that the upper hose part # AC3Z-8260-A was updated as I picked that one up from my local stealership yesterday. They did not have the lower hoses in stock for me to look at. I am going to go to another stealership today and get the balance of what I need. Were BOTH lower hoses updated or do I just need one as I have found conflicting information.
The part #'s for the lower hoses are AC3Z-8286-A and AC3Z-8286-B
Some info lists AC3Z-8286-A to be the only lower hose updated. Is this correct ? Do I only need to replace the upper hose and the one lower ?
cjglenn is offline
post #2 of 6 Old 02-04-2014, 06:19 PM
Replace both.
The updated version for both are white going into the block.
My 2010 had the upper updated but not the lower and it was one of the last truck assembled in Kentucky for 6.4.
Btw the lower was leaking and I had pressure problems since it was bleeding out small amount of coolant.
Only reason dealership found it was they ran dye to check for leaks
GSchretter is offline
post #3 of 6 Old 02-05-2014, 01:33 PM Thread Starter
OK. I went to my local dealership and had them pull all three(3) hoses. ONLY TWO ARE UPDATED. The upper and one of the lower sections(half hose that connects to the engine) The lower half hose that connect from the radiator has NOT been updated by Ford.
UPDATE HOSE PART #'s
AC3Z-8286-A and AC3Z-8260-A
cjglenn is offline
post #4 of 6 Old 02-12-2014, 09:19 PM
6.4L-NREMT-P's Avatar
not to high jack your thread but I'm doing a radiator swap soon and want to change my hoses while I'm at along with T'stats, question is, is there a better place to buy the Hoses and T-stats aside from the stealerships?
2010 F250 6.4L Powerstroke 4x4 King Ranch
S&B Stage 2 CAI
MBRP 4'' DPF/CAT delete pipe w/Bungs
DPF-R plus 70HP tune
EGR Deleted
Custom Intake Elbow
Sinister Coolant Filter
Mishimoto Aluminum Radiator
6.4L-NREMT-P is offline
post #5 of 6 Old 02-13-2014, 04:23 AM
Ive seen em on EBAY.
BurTronn is offline
post #6 of 6 Old 02-15-2014, 06:04 PM
CowboyCody's Avatar
I got a Gates set at a local auto parts store, the guy claimed Gates made them for Ford. So far so good with mine. I think I saved $20.
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
