Cold weather, P006B and P2563 codes. Please help - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-28-2014, 07:35 PM Thread Starter
When I started my truck the P006B code came up (Exhaust Pressure Correlation). It was around 1degrees farenheit. As I was driving down the road another code popped up, P2563 (Turbocharger boost control position sensor A circuit range/performance). It was about -4 degrees Fahrenheit. Is this all because of the cold weather or is my truck falling apart? Also what do the codes mean? Also are these something that I need to worry about or do a lot of you guys get these codes in the cold? Any and all help would be greatly appreciated.
FW SPIN is offline
post #2 of 11 Old 01-28-2014, 07:41 PM
It's nothing serious, you need to clean out your exhaust back pressure sensor. I was throwing the same codes when it was cold like this, I cleaned my ebp sensor and have had no troubles it was -15 here this am.
2010, Deleted and H&S tuned.
Christop73 is offline
post #3 of 11 Old 01-28-2014, 07:46 PM Thread Starter
Will that take care of both codes? Also where is the sensor located? And what is the best way to clean it?
FW SPIN is offline
post #4 of 11 Old 01-29-2014, 07:11 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The ebp sensor definitely needs to be cleaned. Also it could be that your sensor tube is freezing. Several members have had that problem. Check out some of the threads in the 6.4 section. Here is a picture of the sensor and tube.
ID:	235218   Click image for larger version
Name:	6.4 up pipes.jpg
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 11 Old 01-29-2014, 07:21 AM Thread Starter
^^^ thanks for the reply. What should I use to clean the sensor. I haven't deleted the EGR coolers yet. Also I'm running the Spartan 275EL tune, the egr coolers don't cycle and are shut off on that tune so I'm sure that might have something to do with it.
FW SPIN is offline
post #6 of 11 Old 01-29-2014, 07:31 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I just used brake cleaner.
08 F350 cc/sb 4X4
post #7 of 11 Old 01-29-2014, 07:39 AM Thread Starter
I'm having some trouble trying to find the threads for the frozen boost tube and how to remove the sensor. Can anyone lead me to it. Sorry for being so needy lol. But again thanks for all the help guys
FW SPIN is offline
post #8 of 11 Old 01-29-2014, 07:42 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Here you go!
EBP tube icing possible fix.
A new twist on the EBP sensor.
08 F350 cc/sb 4X4
post #9 of 11 Old 01-29-2014, 07:45 AM Thread Starter
^^ Thanks man you've been a big help!
FW SPIN is offline
post #10 of 11 Old 01-29-2014, 10:47 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem
08 F350 cc/sb 4X4
