What's going on guys. Urgent please help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-28-2014, 08:20 AM Thread Starter
Jerzyperson's Avatar
So I had my truck die this morning. Tripped the two following plus a cylinder 2 misfire code and exhaust recirculation or something like that code. What's going on? I do have a bad manifold leak I'm going to fix very soon. But the codes for cylinder two have me worried. What do I need to fix this before I have bigger issues? I do have deletes done. Is it a bad gasket, I'm a little past due on my oil change, could that be it? No leaks, a little blue smoke in the morning but other then that been solid. Except that real bad lope or shimmy in the motor. Only did it in park tho. Any help guys. I really can't afford to be out a truck. Especially replacing the motor....
Jerzyperson is offline
post #2 of 6 Old 01-28-2014, 02:13 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Its hard to say what's causing it but I would get it checked out ASAP. The lope and contribution code could be an injector. You want to get it figured out before it does major damage. Does it make any noise (knock or tick)?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 6 Old 01-28-2014, 02:19 PM Thread Starter
No knock out tick. Only acts up in the cold. Or acts worse in the cold.. and this morning. was the first bit of blue smoke I've ever seen. Hasn't done anything like that since this morning. Been running just fine. with the mild lope.
post #4 of 6 Old 01-28-2014, 02:19 PM Thread Starter
Originally Posted by Jerzyperson View Post
No knock out tick. Only acts up in the cold. Or acts worse in the cold.. and this morning. was the first bit of blue smoke I've ever seen. Hasn't done anything like that since this morning. Been running just fine. with the mild lope. It also stayed and drove fine this morning. It didn't act up till it was idling at the job site..
post #5 of 6 Old 02-01-2014, 11:55 AM Thread Starter
Now it's burning oil. Only at an idle. I just did An oil change and it's a little over full but it's just acting weird
post #6 of 6 Old 02-06-2014, 08:04 PM
a 6.4 is the same problems as a 6.0, ditch the ***** and buy a 7.3 good luck
sean andreano is offline
