Help please - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-15-2014, 08:14 AM Thread Starter
jcook933@gmail.com's Avatar
Angry Help please
Good morning gentlepeople. I recently purchased a used 2010 f250 with 130k on it. I have since replaced the cold side pipe installed 5" downpipe back and am using the gearboxz programmer for the delete and econ tune. Truck has been running perfect for about 1000 miles +. This past Saturday I received a random check engine light. The programmer from gearboxz has a dtc reader, went home plugged her in and it was not communicating. Went to start truck back up no crank no start. Cycle the keys a few time and it started. While running multiple warning lights were cycling on and off. Gauges were not functioning properly ie turning on and off, gear selector light cycling on and off, wrench- traction control- oil- low fuel- coolant temp all on and off. Drove truck, feels like no boost, and cooling fan was running full tilt. Batteries were tested and both good, alternator was replaced, vehicle has aftermarket key in box remote start, and amplifier for door speakers. Amplifier was disconnected unable to locate any " obvious grounds or shorts or frayed wires" I have spoke to some local ford guys and with the DLC not communicating their scan tool will not help. Any ideas? I have read about TX module causing similar symptoms but don't know how to test it. Any help or ideas would be appreciated!
jcook933@gmail.com is offline
post #2 of 10 Old 01-15-2014, 08:15 AM Thread Starter
Sorry TBC module
post #3 of 10 Old 01-15-2014, 09:46 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
there is a harness above your drivers side inner wheel liner.. it likes to get corroded on some rigs, and causes weird issues like this..
it's been said that simply wiggling that thing and seeing if things change is a good indicator if it is a problem.. so... try it?
If it does have an affect, it is a worn/chaffed/shorted wire or wires... which it likely is anyway, but maybe not there... that is just the location that seems to happen most often to folks.
drewactual is offline
post #4 of 10 Old 01-15-2014, 09:49 AM Thread Starter
Ok I'll take a look and try it out thanks!
BEASTPSD
post #5 of 10 Old 01-16-2014, 08:16 AM Thread Starter
Checked connections in that area. No signs of rubbing and cleaned connectors same problem. Occasionally getting check brake system and trailer brake module fault. Any suggestions appreciated.
BEASTPSD
post #6 of 10 Old 01-16-2014, 11:55 AM Thread Starter
Took to dealer to maintain my sanity. Fingers crossed it is something cheap
BEASTPSD
post #7 of 10 Old 01-24-2014, 09:35 PM
did the dealer find out what was wrong with your truck?
2009 F 250 Lariat 6.4 PSD
cterrebonne is offline
post #8 of 10 Old 01-24-2014, 10:03 PM Thread Starter
TCM had a short in it which was causing the can bus system to have intermittent shorts. Basically a bunch of gibberish until the tech explained it to me. All is well now and only out 750
BEASTPSD
post #9 of 10 Old 01-25-2014, 08:40 AM
I am glad to hear that. Electrical issues are always a pain.
post #10 of 10 Old 01-25-2014, 08:50 AM Thread Starter
Yes they are!!!
BEASTPSD
