2008 Ford F-350 Dully Starting Problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-13-2014, 09:28 AM Thread Starter
Hi
Here is my problem with the truck as the best I can describe.
I left out of town for 3 month, no one drove my truck in that time my wife she started once
when I put the key on the light on the dash come on dim and if I try to crank it nothing will happen. it feels like the battery is dead, even the light on the dash will go off
now if I wait for 20 sec with the key being on the on position the light on the dash will go fully on, then if I crank it, it will crank but it will not start
I will have to leave it cranking until automatic shuts off wait for 10 sec then crank it.
Then it will crank normal drive normal and act normal
Please advice
kokowawa is offline
post #2 of 3 Old 01-13-2014, 09:42 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 66 Post(s)
clean your terminals, apply vasoline (it WILL NOT corrode with vasoline on them), check your ground straps.. check your batteries under load... check, clean, vasoline the connection on the alternator(s)..
I bet your problem disappears with a good connection.. If the bats are strong enough to turn the engine in ten second go-at-em's, I bet it's fine..
drewactual is offline
post #3 of 3 Old 01-13-2014, 12:14 PM Thread Starter
I did try that it did not work...
but I had one of my friend come and check it
it was one of the relay's I will post the name of it later
the code that was showing P0231, U0151, U0121 and P2291
All the codes are gone
kokowawa is offline
Tags
electric start , engine , fuel pump
