Swollen intercooler? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-10-2014, 10:05 AM Thread Starter
The intercooler on my 08 job 1 had swollen on the first two or three rows. The first row is starting to pull away from the fins. I run idp extreme street and can easily peg the boost gauge. Do I have a faulty intercooler? Will another stock one do the same thing?
KoryVette is offline
post #2 of 5 Old 01-10-2014, 10:52 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 60 Post(s)
This.... Is a new one..
I'd guess you can peg easily because it's leaking.. I bet its leaking because of an obstruction caused pressure to find another way out.. you no doubt have a faulty intercooler now, but what made it fault is the question..
As an aside.. what kind of freakin boots are you using? I may be needing those.. :-)
drewactual is offline
post #3 of 5 Old 01-10-2014, 11:35 AM Thread Starter
This is not a new intercooler. It has 14k on it. The turbos have 2k on it. The boots are stock. Truck has 80k on it. Any idea where to look for the obstuction. Or testing procedures?
post #4 of 5 Old 01-11-2014, 05:30 AM Thread Starter
Where is the booost sensor? It has to be before the obstruction. Im not sure there is a leak but the theory of a obstuction sounds plausable.
post #5 of 5 Old 01-13-2014, 08:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The map sensor is in the intake manifold
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
