6.4 Engine issues - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-06-2014, 08:07 AM Thread Starter
6.4 Engine issues
Yesterday I went and dropped some people off at the airport. Truck ran perfect on the highway for 2 1/2 hours or so. I dropped them off at the front door and proceed to find a parking spot. After I found a spot I shut the truck off and headed back for the airport to say good bye.
I came out and went to start the truck. I turned the key and nothing, no click no slow turning over just nothing. Everything else had power. I proceeded to check any fuse related to start problems. I couldn't find one thing wrong with any fuse's.
I checked the spartan programmer for code and their was 2 PCM related codes but forgot to right the # down. I loaded the stock tune back on and the truck would roll over but would not start. I proceeded to load a 300hp tune. After that tune was loaded I tried to start. Truck rolls over fine but I only have 300 psi or so of fuel rail pressure.
Now I'm leaning more towards a computer problem rather then a HPFP issues as my original problem was no start and I think the truck has went into a fail safe mode loading the tunes back and forth without actually running the truck.
How would I be able to check this or would it be a dealership trip?
Trouble maker is offline
post #2 of 5 Old 01-08-2014, 07:48 PM
trade it for a 7.3
sean andreano is offline
post #3 of 5 Old 01-08-2014, 09:03 PM
srjd's Avatar
Quoted: 2 Post(s)
Wow really ^^^^^^
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 5 Old 01-09-2014, 01:32 AM Thread Starter
A non running 6.4 is just about quicker then a 7.3 so I really wouldn't be getting to far ahead.
post #5 of 5 Old 01-10-2014, 05:41 AM
kylebryan's Avatar
I've had issues with mine before where I had to get up under the truck and jump over the starter to get it running. Kind of sucks and its hard on your screwdrivers too lol
2010 F-250 6.4L CC/SB/FX4. Spartan Tuner, 4" Turbo Back Exhaust
kylebryan is offline
