whining noise (video) - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-05-2014, 04:52 PM Thread Starter
countryboy73703's Avatar
I had already posted about a whining noise, thought it was my power steering pump, but it wasn't, I've replaced pump, and both idler pulley's. still no change. the sound originally started at random, and actually right after I installed a leveling kit. I took some video, and regardless of being in drive, or park, or neutral, or speed it still makes the whine, it gets louder with RPM's only. steering back and forth does not effect the the whining noise. HELP, Dealer wanted 230$ to diangose, which I think is crappy, so I'm taking another jab at this, hints why I'm including video's this time.
one video is in park, the other is while driving, and hitting a few speed bumps.
2008 f250 fx4 crew,spartan tuned running 250hp, dpf/cat removed with 4" turbo back, RCX 3" lift, 35's on stock 18's (for now), and lots more in the near future
Active Duty Navy, Machinest Mate
countryboy73703 is offline
post #2 of 15 Old 01-05-2014, 05:12 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would think its the power steering pump as well. Does it change in the cold weather?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 15 Old 01-05-2014, 05:30 PM Thread Starter
Well as stated, I replaces the pump, as well as the idler pulley's. Before I changed the pump I had flushed the system as well and replaced fluid and no change. Temp of fluid doesn't seem to matter, maybe a slight bit louder, but only I can tell cause I hear it everyday.
post #4 of 15 Old 01-06-2014, 12:19 AM
Your Video clips didn't help... since you installed a leveling kit it could be the flex pipe(s) from the exhaust manifold that leads to the turbo, look for leaking. it is pretty common that pipes get stress out when changing truck height
VictorFordTech is offline
post #5 of 15 Old 01-06-2014, 04:41 AM Thread Starter
Somebody on another forum mentioned that it sounded like diodes on the alternator
post #6 of 15 Old 01-07-2014, 05:45 AM
Quoted: 2 Post(s)
getting that same noise that you describe. sounds exactly like a power steering pump low on fluid. my fluid level is fine, and the noise doesn't change when i turn the wheel. only changes tone when i accelerate. seems to get louder the colder it is outside. this morning was 4*F and it was the loudest i've heard it to date. seems to get more quite when the truck is all the way warmed up.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #7 of 15 Old 01-07-2014, 05:49 AM Thread Starter
Ya... Sounds like my symptoms. If you figure it out please let me know.
post #8 of 15 Old 01-07-2014, 03:56 PM
Quoted: 2 Post(s)
so i double checked my power steering fluid level.. it was just a tad below the min line. stopped at walmart and picked up some Mercon V ATF and filled it to the max line. The sound is gone. Hope yours is as easy to solve as mine was... not sure why mine was low. its not leaking anywhere.
Kris
post #9 of 15 Old 01-07-2014, 03:59 PM Thread Starter
My fluid is on the full mark and has been that way. Luckily yours was a simple fix. Mine on the other hand is not being so simple
post #10 of 15 Old 01-10-2014, 09:11 AM Thread Starter
Bump
Any other ideals guys?
The Following User Says Thank You to countryboy73703 For This Useful Post:
64strokin (01-20-2014)
