Deceleration Noise (Not Grinding) - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-05-2014, 02:48 PM Thread Starter
I noticed the other day that my truck was making a weird "unloading?" noise when I let off the throttle after moderate to hard acceleration. Almost sounds like a loud blow off or something, a rush of air. It sounds like at coming from the passenger side under the hood. Not too sure what it could be. I checked the boot for my air intake and it seems tight. I have an aFe stage II with PG7 filter, H&S Mini Maxx and MBRP 5" straight pipe from the down pipe back. Also a Flo Pro EGR delete. I never noticed the noise until a couple days ago so it think it just came up recently. Any idea what this could be?
rmzsuzuki89 is offline
post #2 of 5 Old 01-08-2014, 02:53 PM
How cold was it? I had something similar but I could tell mine was coming from the turbo since my gauge was telling me i was putting way to much boost for what I was doing. My truck sat outside all day in below freezing temperatures. The morning temp was -2. Is you truck still doing it? From what I found online that it might be my EBP sensor or tube. My unloading noise when away after my truck warmed up a bit.
jneff89 is offline
post #3 of 5 Old 01-08-2014, 05:29 PM Thread Starter
My truck is still doing it. It is not too cold now, maybe around 60 degrees. It was in the 40's but it was doing it a little before then. It seems like it has gotten a little louder. I could just be imagining that though being paranoid.
post #4 of 5 Old 01-08-2014, 10:10 PM
srjd's Avatar
Quoted: 2 Post(s)
If its a whoosh its just your turbo. If you build lots of boost then let off all that pressure has to go somewhere. Its not your ebp that's a whole other story
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 5 Old 01-09-2014, 06:19 AM Thread Starter
I figure it has to be something with the turbos like you said. I have always heard them when I let off the throttle but it is so much louder now. I can also hear them spoil a lot more than I have before. The boost levels seem the same as they usually were. Around 10lbs cruising at 70mph.
