Squeal at high boost - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-04-2014, 07:53 PM Thread Starter
jhanso22's Avatar
I have a high pitched squeal at high boost. I can only make it happen at 38-45 pounds of boost on the highway tc locked up (passing a herd of slow pokes). I've checked my all of my boots and piping it all seems ok where should I look next? I don't think it's an up pipe because my truck will hold it's boost and egts are normal. I feel like it's boost pressure related but was told that sometimes blown headgaskets will squeal I don't know if I have one or not. Degas symptoms seem normal and no puking. I'm kind of lost I first noticed it after ebp sensor relocate but have re done it twice and used new gaskets and fittings. Any ideas?
Sent from AutoGuide.com App
2011 F-250 Lariat CCSB-5" exhaust, spartan tuned, Carli lift with King Pin-Top 2.5
2010 F-450 Lariat CCLB
2006 F-250 XLT ECLB
2008 F-350 Lariat CCSB
1999 F-350 Lariat ECSB
jhanso22 is offline
post #2 of 4 Old 01-05-2014, 09:05 PM
Since 6.4L are getting old already, Most likely is, : -Engine uses a laminated steel gasket. noise is the result of an exhaust leak at exhaust manifold. most likelly passager side, look for broken studs (exhaust manifold bolts). hope this help.
VictorFordTech is offline
post #3 of 4 Old 01-06-2014, 05:01 PM Thread Starter
jhanso22's Avatar
Thank you for your reply I will check tomorrow. Will it be obvious like soot every where? Or very subtle?
2006 F-250 XLT ECLB
jhanso22 is offline
post #4 of 4 Old 01-06-2014, 08:12 PM
I am not sure about it. but a good signal as always will be broken studs.
