Fuel/Water and Wrench icon - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-02-2014, 04:31 AM Thread Starter
I have a 2010 F-250, 61K on it.
Traveling down I-95 back to NC and my Fuel/Water Light comes on as well as the nice little wrench Icon. Truck goes into limp mode and I manage to get it back home. Two days prior to this my Fuel/Water light comes on and I have it drained.
Took it to the dealer this morning and they are gonna check it out. Is this a fuel/water issue or could it be something different?
Cabelas10 is offline
post #2 of 5 Old 01-02-2014, 08:12 AM
Could be a bad sensor.
Or maybe it's dirty. The last time you drained the water separator, was it a smooth stream of water/whatever and then fuel, or was it a trickle or a drip? If it's not draining properly, it's probably clogged up with gunk and needs to be cleaned out.
How often do you drain it?
B. Adams is offline
post #3 of 5 Old 01-02-2014, 12:38 PM Thread Starter
Apparently I do not drain it enough. Didn't know it was recommended to drain it once a month. However, I drained it Monday and the lights came on yesterday.
post #4 of 5 Old 01-03-2014, 05:31 PM
Powerstroke Techie
You need to have the cheese cleaned out of the bottom of the HFCM, likely the sensor replaced, and a WIF reset done with IDS.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #5 of 5 Old 01-05-2014, 04:48 PM Thread Starter
Yep, it threw a P2269 code. Had to have the HFCM cleaned and the WIF sensor replaced. Good times!
