fuel separator spunk - Ford Powerstroke Diesel Forum
post #1 of 16 Old 12-27-2013, 09:27 AM Thread Starter
theplumbingmedic's Avatar
Hey guys i usually drain my water separator every month or so and i have never seen much water to speak of. I drain about 1/2 a pint into a Gatorade bottle sometimes i let it sit most times i dump it right away.I usually fuel up at one of 2 stations that sell a decent amount of diesel , i base that on that i have to wait in line for a truck or two each time i fill up. Well i went to drain the separator and it barely dripped out.I went to ford and was robbed of$42 for a small pack of parts, disassembled the front cover of it and after a refreshing diesel bath i got it off and found the holes on the inside were packed with a kinda whiteish goo maybe a little thinner than white lithium grease.What the hell is this chit? I have run 1 full tank with power services artic formula this season. Any ideas ?
Thanks
Mike
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #2 of 16 Old 12-27-2013, 10:16 AM Thread Starter
Any one?
exhaust
post #3 of 16 Old 12-27-2013, 10:31 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Its just gunk that builds up there. I also had this happen. Maybe this thread will help. Just take the cover off and clean all that crap out.
HFCM manifold cover - fuel line removal?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 16 Old 12-27-2013, 10:59 AM Thread Starter
Thats what i did.I really was surprised how much was in there.What is it and how does it develop ?
exhaust
post #5 of 16 Old 12-27-2013, 11:51 AM Thread Starter
any one have any ideas?
exhaust
post #6 of 16 Old 12-27-2013, 12:39 PM
pops250's Avatar
Mine has done the same thing 2x in 70000 miles. I drain it weekly but still happened. I think it must just be stuff filtered from the fuel. It is aggrevating though.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
post #7 of 16 Old 12-27-2013, 01:00 PM
Quoted: 2 Post(s)
Mike... i get some of that white stuff you speak of when i drain mine every now and then.. i'm about to change my oil this weekend and i'll be draining mine. i'll also check my dads...
what stations are you fueling up at?
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #8 of 16 Old 12-27-2013, 01:04 PM Thread Starter
wawa in woodbridge (new tanks as of this past spring) and sheetz on RT.15 in haymarket
exhaust
post #9 of 16 Old 12-27-2013, 01:05 PM Thread Starter
What did your dad end up getting kris?
exhaust
post #10 of 16 Old 12-27-2013, 01:52 PM
I had a light tan slurry and chunkies come out of mine the last time I drained it. I shot alot of brake cleaner into the hole and more came out! I sprayed until no more chunkies came out. I let it sit for about 20 minutes to dry then reinstalled the plug.
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
