Sever squealing on cold start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-26-2013, 11:46 PM Thread Starter
MudWild033's Avatar
The squeal started once the temp dropped below 40 degrees and has been getting worse ever since. The temp is now 0 or below when I start the truck in the morning and the squeal is loud enough to drain out the sound of the motor. Serpentine and AC belt were replaced just before fall. The sound completley goes away once the truck warms up... what could this be?
2008 6.4 stroker, Spartan, MBRP 5", S&B cold air, RCD EGR delete
MudWild033 is offline
post #2 of 5 Old 12-27-2013, 06:58 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would start with the belt tensioners and idler pulleys. They are common problems.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 5 Old 12-27-2013, 08:17 AM
AllGo'N'Show's Avatar
Is it belts or exhaust sound? When squealing, give it a blip on the throttle, does the tone change at all, higher/lower/more/less/stop?
When you did the serp and AC belt did you do any idlers or tensioners? If not, start there for sake of your new belts anyways.
'16 F450 6.7L Lariat Ult. .:. Tow-Rig
'08 F350 6.4L XL .:. Gone to a new home
Alradco .:. H&S+GH .:. RCD .:. PDR .:. S&B .:. aFe .:. Absolute .:. Fluidampr .:. Toyo .:. Black Rhino
Enjoy horrible service, sub-par quality and made in China product? Mishimoto is your one stop shop!
AllGo'N'Show is offline
post #4 of 5 Old 12-27-2013, 07:54 PM Thread Starter
MudWild033's Avatar
The more I listen to it the more it sounds like a squeaky belt. The sound is intermittent, not constant, like a squeaky bearing or pulley would make. I just don't get why it goes away when the the truck is warm. I'm going to try spraying the belts tomorrow with belt dressing just to see if the squeak stops.
post #5 of 5 Old 12-27-2013, 10:53 PM
diesel23's Avatar
Quoted: 7 Post(s)
Feedback Score: 14 reviews
As 04hdfatboy said , replace the BELT TENSIONER !! They go bad and are notorious for this
diesel23 is offline
