2008 6.4l DPF - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-24-2013, 08:18 AM Thread Starter
TwinTurbo6.4's Avatar
Quoted: 80 Post(s)
2008 6.4l DPF
I had a friend that had an issue with his DPF. I'm unsure if they could be linked, but his check engine light came on saying the DPF was bad with "high voltage." Could the dpf cause the battery to get High voltage, maybe the Alternator putting out too much voltage, sensor? Has anyone came across this?
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
