2007 f350 headlight issue - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-15-2013, 05:03 PM Thread Starter
Chefus's Avatar
I'm having an issue with my headlights!
First the low beams stopped working all of a sudden. I tried man handling the switch and got the to work, here and there then not at all.
The other day the day lights just up and quit.
I've replaced the switch, all fuses and bulbs.
The running and high beams work so do the interior lights and instrument.....
HELP!
Chefus is offline
post #2 of 14 Old 12-15-2013, 05:08 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
Headlight relay maybe? Shot in the dark, but since you've replaced the switch, its all I can think of.
wvrrcarknocker is offline
The Following User Says Thank You to wvrrcarknocker For This Useful Post:
Chefus (12-15-2013)
post #3 of 14 Old 12-15-2013, 05:20 PM Thread Starter
Chefus's Avatar
What relay? I've looked at the fuse diagram and it doesn't show one....would love it to be that easy!
Chefus is offline
post #4 of 14 Old 12-15-2013, 05:32 PM
Quoted: 2 Post(s)
I am guessing 301 in the Power Distribution Box under the hood. Full ISO Relay DRL#3 (Daytime Running Lamps). Could be 205 or 206 1/2 ISO Relays for DRL#1 and DRL#2, but i'd bet on 301. I'd pull the one from 303 (Blower) as long as you know your blower is functioning correctly, and swap it into 301 and try it.
Chefus (12-15-2013)
post #5 of 14 Old 12-15-2013, 05:34 PM Thread Starter
Chefus's Avatar
Right on! I'll give that a try.... Thanks!
I'll let you know if that works!!
Chefus is offline
post #6 of 14 Old 12-15-2013, 05:46 PM Thread Starter
Chefus's Avatar
That fixed the daylights! Is there another for the low beams?
Chefus is offline
post #7 of 14 Old 12-15-2013, 05:50 PM Thread Starter
Chefus's Avatar
One thing that was a problem, the cover was missing on the box. I wonder if moisture is causing me grief? I have since replaced the cover. Wonder if I should replace all the relays you mentioned.
Chefus is offline
post #8 of 14 Old 12-15-2013, 05:50 PM
Quoted: 2 Post(s)
Again, this is a shot in the dark. Try taking 201 and 202 out, and putting them in 205 and 206.
post #9 of 14 Old 12-15-2013, 05:51 PM
Quoted: 2 Post(s)
Your relays probably are corroding, i'd replace every relay in that box, to be totally honest.
post #10 of 14 Old 12-15-2013, 05:52 PM Thread Starter
Chefus's Avatar
Will do! The last trick worked so.......
I'll be back.
Chefus is offline
