P008C how do I fix this? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-11-2013, 07:19 PM Thread Starter
Jerzyperson's Avatar
My truck keeps tripping three codes, P100 OBD2 compatibility test not competed or something like that. Turbo performance code. And the one stated in title. That's the only code that trips the check engine light, and did start popping up till I got my truck tuned. What can I do to fix it, or what is causing it? Thank you guys in advance
Jerzyperson is offline
post #2 of 7 Old 12-12-2013, 11:53 AM Thread Starter
Bump
post #3 of 7 Old 12-12-2013, 12:34 PM Thread Starter
My fuel temp level got high as well. Hit 140. What ifs going on. I know the fuel cooler pump is on the driver side lower fan shroud. also have a coolant leak from that area. anybody help please. not sure what's going on here.
Side note. What do I need to do to check the fuel cooler. Do I need to remove wheel well? Cause I can't find or see it
post #4 of 7 Old 12-13-2013, 01:23 PM Thread Starter
Is this bolt hole supposed to be empty?
post #5 of 7 Old 02-19-2014, 09:09 PM
No but it's just a mounting bolt for that tank
08 King Ranch 6.4 is offline
post #6 of 7 Old 05-16-2014, 03:40 PM Thread Starter
Ok guys I really need help. I can't seem to find fuel cooler plug on the shroud. It's an oem circuit somewhere and I know my pump isn't working. Could it be bad pump? Or open circuit. It sits at 138 once truck gets to temp. Blows lots of black smoke, lacking power for sure. Please help
post #7 of 7 Old 05-16-2014, 07:56 PM
Have you tried looking for a master service manual? I'm sure that could point you to where it is located. There is usually a PDF format of one online somewhere. Sorry I can't be of more help but that the best idea I have for you.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
