Head gasket? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-08-2013, 01:17 PM
tim4runner
Guest
Posts: n/a
Quoted: Post(s)
Head gasket?
So my '08 has developed some strange issues. As it warms up I get hot air between about 100 and 170 degrees ect, then it blows cold air. The temp will steadily rise to about 200, when I get hot air again, then drop to 192 where it stays. Hot air is hit and miss from there. Egr and dpf are in the landfill, using mini maxx mildly tuned. Installed new thermostats last weekend with no change. Also pukes coolant sometimes at 20 psi boost, sometimes not at 40 psi. Any guesses? I'm in southern Alabama if anyone knows a reputable mechanic here.
Thanks
post #2 of 3 Old 12-10-2013, 01:08 AM
tony97gt's Avatar
Is it blowing hot when you idle and cold when you drive? Could be a radiator fan.
Could it be the blender door on your a/c?
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #3 of 3 Old 12-10-2013, 02:49 PM
tim4runner
Guest
Posts: n/a
Quoted: Post(s)
Temp drops quickly when I stop. This morning it got up to 134 degrees, then dropped to 120 and stayed there for most of my drive to work.
