Pegging the boost gauge???? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 28 Old 11-25-2013, 01:21 PM Thread Starter
Combat_Infantryman's Avatar
I am very concerned about pegging out my boost gauge. If I get on it pretty decent between 1/2 and 3/4 throttle my boost gauge pegs out. I would like some advise and opinions.
I just installed a Spartan tuner, running the 210 L/L tune and a Pro-FLO 4'" exhaust turbo back exhaust with DPF delete. My truck feels awesome compared to my old stock set up. I am just scared I am going to tear something up.
I have a 2009 King Ranch Super Cab 4wd.
I ordered a S&B CAI that has failed to arrived in a timely manner. Will this addition hurt or help my current problem?
EGR Delete kit and Coolant filter kit is here at the house. I like installing one thing at a time, just to see differences.
2009 Ford Super Duty F-250
King Ranch 4x4
6.4L 8 Cylinder Power Stroke
Spartan Tuner
Pro-Flo 4" turbo back exhaust
S & B Intake
Sinister EGR Delete w/ high flow intake elbow
Sinister Coolant filtration kit
Combat_Infantryman is offline
post #2 of 28 Old 11-25-2013, 02:39 PM
How fast are you going? Are you pulling anything? Most of the time my boost gauge is between 5 and 20psi. The only way I go even above thirty is if I am really getting on it hard or my stepdad is using my truck to pull his 28 ft crownline boat over 100mph. It is something to keep your eye out for. Check your turbos to make sure everything is normal. If the there is boost, at least you know the turbo is working.
jneff89 is offline
post #3 of 28 Old 11-25-2013, 02:54 PM
Quoted: 47 Post(s)
The only problem you have is mathematical. The boost gauge goes to 40psi, a tuned truck (Spartan, H&S, etc.) can easily boost more than that.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, Westin Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #4 of 28 Old 11-25-2013, 05:29 PM Thread Starter
So I should be ok. I just produce more boost than the gauge reads?
post #5 of 28 Old 11-26-2013, 06:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I know a lot of trucks make high boost. I think its more in the tuning than anything. I have a 71mm lp turbo and I don't see much more than 42 lbs of boost even from a hard pull. I think tuning has a lot to do with it. I am going to try gearhead tunes eventually. Also the more restrictions you remove the boost should go down but make the same amount of power.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 28 Old 11-26-2013, 06:17 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Another thing you may want to do is take off and clean your ebp sensor and tube and your map sensor.
08 F350 cc/sb 4X4
The Following User Says Thank You to 04hdfatboy For This Useful Post:
GSchretter (11-26-2013)
post #7 of 28 Old 12-04-2013, 06:25 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
are you tuned? a tuned truck will peg a 40psi boost gage all day long....if you run a mini max you can set a defuel on boost... i ran mine at 50psi max for a bit... blew the head.... i defuel at 40 now...
08 F350 MINI MAXX,5"FLO-PRO DPF DELETE, AFE INTAKE,HID'S,BFG A/T'S ON 20" BMF NOVAKANES,TIMBREMS,BLACKED OUT BUMPERS GRILL,STEPS RACING STRIPES,PAINTED HEADLIGHTS ,FABTECH LEVELD,RCX DUAL STABILISERS
INJEKTER1 is offline
The Following User Says Thank You to INJEKTER1 For This Useful Post:
GSchretter (12-05-2013)
post #8 of 28 Old 12-04-2013, 02:21 PM Thread Starter
I am tuned. I now know how to monitor my boost on my DASHDAQ. My factory boost gauge was a little off too.
King Ranch 4x4
Spartan Tuner
S & B Intake
post #9 of 28 Old 12-16-2013, 11:09 AM
Powerstroke Techie
I've bounced stock tune trucks off 40PSI before.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #10 of 28 Old 12-16-2013, 11:54 AM
Quoted: 47 Post(s)
How did you pull that off?
