Buying One ?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-16-2013, 07:53 PM Thread Starter
Buying One ??
I am thinking of trading my 5.9 Cummins in on a 6.4 psd. What common problems am I going to have and I mean what are the EXPENSIVE ones?
Thanks
Sent from AutoGuide.com App
jerrodlk is offline
post #2 of 5 Old 11-16-2013, 10:32 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Well the high pressure fuel pump is on the rear of the engine above where the engine and tranny meet, can't replace that without removing the cab. Since you have the cab off you might as well replace up pipes, oil cooler, and stud it. Then you might as well dump a few more $$$ here and there. Got a truck fund? Might not need it but you might so.
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
The Following User Says Thank You to mts678 For This Useful Post:
GSchretter (11-28-2013)
post #3 of 5 Old 11-19-2013, 02:53 PM
sschefer's Avatar
Thanks
Don't and they are all expensive. I've got an 08 and it's in the shop at least once every 3,000 miles. I have the platinum extended warranty and I'm putting it to the test right now. As soon as it gets out of the shop it's gone.
Steve Schefer
Santa Rosa, Ca
08' F350 Super Duty 4x4 OffRoad. 6.4l, Fabtech 6" lift, Procomp 20" wheels/Toyo 37's, K&N Intake. 9" total over stock lift.
sschefer is offline
post #4 of 5 Old 11-23-2013, 08:02 PM
I WOULD KEEP THE 5.9 OVER THE 6.4 ALL DAY LONG, AND AM A DIEHARD FORD GUY AND HATE DODGE. THE 6.4 IS A NEWER 6.0. PIECE OF **** PROBLEMS. IF U WANT A FORD GET A 7.3, MAYBE A 6.7
sean andreano is offline
post #5 of 5 Old 11-23-2013, 08:17 PM Thread Starter
Well thanks guys. I will not be getting a 6.4. I will keep driving the good old 5.9. Made my mind up after watching a YouTube on lifting the cab. Not that the 5.9 is perfect either cause it has it own problems too. I have already fixed everything on my truck and it's pretty solid now and I don't want to go through that with another truck. Thanks again.
jerrodlk is offline
