Strange noise - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-12-2013, 05:27 PM Thread Starter
Strange noise
Today I was running between 85-90mph on the road and started hearing a sound like a squealing speedo cable. A friend who was in the truck said it sounds like the turbos about to fail, is this correct or could there be another, hopefully less expensive problem? I was about to look into trading the truck in and don't want to have to do any expensive repairs, if I do I may as well keep it.
2008 F-250 H&S Mini Max, Flo-Pro Cat & DPF delete, AFe cold air intake
If voting could actually change anything it would be illegal!
SamuraiBigEd is offline
post #2 of 4 Old 11-13-2013, 08:39 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would guess either a belt tensioner or idler pulley.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 11-14-2013, 06:25 AM Thread Starter
That was my thought also but the noise sounded like it was literally coming from right behind the instrument panel. My friend actually turned and looked right at the same spot I was which is what lead us to the turbo assumption.
post #4 of 4 Old 11-14-2013, 06:28 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Also an exhaust leak might cause a squealing noise. Check the up pipes for soot to make sure they aren't cracked. Also take a look around the exhaust manifolds.
08 F350 cc/sb 4X4
