Security light flash/no start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-06-2013, 04:38 PM Thread Starter
HawkeyeStroker's Avatar
Truck fired up like normal, went to turn out of the parking lot and the truck died. The security light was flashing and I couldn't get it to do anything. No start. So I pulled the positive cables off the batteries and hooked them back up and it fired right up and hasn't done it since. Ive noticed others have had this issue, just want to see if anyone has found a definite answer for this. now feel like I cant trust the truck if I never know when its going to do this. Is it something with the key? Or the pats module? Any information is appreciated. The truck is Spartan tuned.
2008 F250 ccsb lariat
Spartan Tuned
AFE CAI
Flo Pro Exhaust
Flo Pro EGR delete
Flo Pro CAC pipe
HawkeyeStroker is offline
post #2 of 3 Old 11-07-2013, 07:57 AM
tonsofduty's Avatar
I had this problem a few months ago. Very frustrating to say the least. In my case there was a wire corroded under the passenger side battery box. If you look over the forums enough you will see many others had the same problem, yet the fix was completely different. My truck would not fire again no matter what, so I had to go to the dealer since I could not find the issue. There are several modules which need to be satisfied to make the truck start, so it could be a module or the wiring to any one of them. I chased the wiring to the transmission control module (TCM) for a day, and also traced many others. I know this is not great news, but if you can find a damaged wire you may solve the problem, you may not. Good luck.
tonsofduty is offline
post #3 of 3 Old 11-19-2013, 02:28 PM
BigRed08F250's Avatar
Had the same thing happen to me. Backing out of my driveway truck just died and the security light was flashing. Pulled cables off of batteries and cleaned them and truck fired up. One month later I stopped at a store come back out and same thing again. I had to have it towed this time. Got it home and changed both batteries all has been good now for 2 years. Batteries were original motorcrafts that were 3 years old.
BigRed08F250 is offline
