P2291 Won't start.... HPFP? - Ford Powerstroke Diesel Forum
post #1 of 83 Old 11-05-2013, 04:02 PM Thread Starter
NEW UPDATE: Well its down again with same issue!!!! Was cruising down highway and I felt it kinda give out then go again and I watched the fuel pressure go from in the 10's to ZERO! So I coasted to the next turnoff, let it sit for 10 mins. Started back up made it another half mile then she was done again... I heard the AirDog over amping and some cavitation so after about everything being replaced in the fuel system I can only reasonably think that it has to be an issue in the tank. Once the fuel settles for a few minutes its starts back up only to die again... I've got oven 5 grand put into this since it first started acting up... I'm thinking the only thing I can do now it drop the tank, check the sending unit, check tank for debri, and install the single tube sump system in there...
UPDATE: As of today they still havent figured out the exact issue with the truck. They believe its the FASS system returning the fuel to the filler neck instead of sending it to the engine. They said they got the truck to start if the pinch the return line... Throwing the stock system back on to check... Been almost a month since I've had my truck.......
So I've been fighting with my truck for a little while now. About to throw in the towel...
Bought the truck a little over a month ago. Has 40K miles on her.
08 F350
All the normal bolt on mods, down pipe, exhaust, intake, egr delete, fass system, mini maxx...
I'm getting a P2291 code, its the only code I'm getting. I can get it to start just to have it die a few seconds later. I have changed both filters on the fass pump, and the fuel filter on the engine. Tank has plenty of fuel. Get only a small amt of air out of the strator valve but never get any fuel...
I've heard from a few people it could possible be the fass pump... Or more than likely the HPFP. Anyone else have any input or ideas on things I could try before having to send it in for a hpfp replacement? Any help/input would be greatly appreciated. Thank you!!!
2008 Ford F-350 CC/LB 4X4
Hoosierdiesel is offline
post #2 of 83 Old 11-13-2013, 12:56 PM Thread Starter
Dealer called today... HPFP... Said it could be as high as $4796 final bill.
post #3 of 83 Old 11-14-2013, 11:39 PM
I would think, if yor not getting fuel out of strator valve it would be your lift pump, or fass pump that has died, you are taking the strator valve loose and cycling the key, it should blow fuel out good
Ambulance39 is offline
post #4 of 83 Old 11-14-2013, 11:41 PM
I have the same problem, although I just completed rebulding the motor. P2291, I've bled the system good but it still pops the code and doesn't start.
post #5 of 83 Old 11-15-2013, 02:38 PM Thread Starter
Thats exactley what I thought too. I was getting quite a bit of pressure at the filter on the fass system though. I know that pump was working buy I dunno if maybe just not enough pressure... I knew ford would automatically go with the hpfp. I just kinda ran out of options other than getting a new fass pump and hoping that was it. I need the truck working though so I couldnt keep messing with it.
Suppose to hear from dealer tomorrow on its status. They should have gotten parts in yesterday...
post #6 of 83 Old 11-26-2013, 02:24 PM Thread Starter
Well 2 1/2 weeks later and about $3400 later I got my truck back. Only to have the tech say he doesnt even think it was the hpfp. Said the fuel gauge was not working properly and may have ran it out of fuel.... Dont know how/why the tech would change out a hpfp when it was possibly just out of fuel....
post #7 of 83 Old 11-26-2013, 03:27 PM
srjd's Avatar
Quoted: 2 Post(s)
I got this code today after replacing fuel filters. Cycled the key 6 times. Truck stumbled and picked rough for a few seconds threw a wrench. I shut it off cycles the key a few more times cleared the code and no more issues fuel pressure read the normal 4.8 at idle on the mini. I'm thinking you just had air in the system. I'd argue them on the bill they should cover some of it. St least the labor for mis diagnosis
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #8 of 83 Old 11-27-2013, 04:19 AM
The service manager will probably deny what the tech said. After having this problem with my truck I remembered there is a specific procedure for clearing air out of the system. I'm not sure where I found out about it at the dealer or on one of these forums. I can post it if y'all like.
post #9 of 83 Old 11-27-2013, 01:40 PM Thread Starter
One of the techs that worked on my truck spent some time on the phone with FASS and figured something out I didnt know. FASS says their system doesnt NOT self prime and when it loses it prime the truck will not start. You have the fill the water sep. filter with fuel and loosen the fuel filter while the pump is running to re-prime. Happened to me again today but after I primed it she started right up. Didnt throw any codes through...
Wonder if its the same with the AIRDOG, pretty much has to be I'd think.
post #10 of 83 Old 12-05-2013, 01:54 PM Thread Starter
Updated ^
Cant wait to go in and talk to them about the 4k they charged me that fixed absolutely nothing. They'll probably try to charge me some more.... lol.. not going to go over well.
