Is it normal for the idle to rise? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-02-2013, 05:13 PM Thread Starter
Question Is it normal for the idle to rise?
it happens everytime I start it up in the morning, itll be in the low 700's RPM and then it raises quite fast within about a minute up to 830-850 RPMs is that normal or is there something I should be worried about?
western762 is offline
post #2 of 9 Old 11-03-2013, 06:53 AM
08PowerstrokeFX4's Avatar
No it is normal, when it is below a certain temp the PCM will raise the engine idle to bring the temps up to a norm.
F250 CCSB 6.4L Powerstroke
Spartan Tuned, ATS Trans, Sinister Diesel Goodies, Elite Diesel Goodies, and a bunch under the hood.
We miss you Ron. Thanks for everything you did for us and sharing your knowledge!
08PowerstrokeFX4 is offline
post #3 of 9 Old 11-03-2013, 09:53 AM Thread Starter
phew!!! you put my mind at ease lol, thank you so much!!!!
post #4 of 9 Old 11-04-2013, 11:49 AM
not a problem at all!
post #5 of 9 Old 11-07-2013, 07:33 PM
TD-5's Avatar
Quoted: 3 Post(s)
I believe its programming in the PCM they call the "cold weather idle strategy". If the ambient temperature is below something like 48F & the engine idles for more than 130 seconds the cold weather idle strategy is initiated & will increase the rpm's to between 800 & 1200 rpm depending on how far below activation temp the ambient temperature is.Touching the brake pedal momentarily will reset the base idle time. The strategy will remain active until the engine coolant temperature reaches 158F. I may not have the numbers right but that's how it was explained to me.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #6 of 9 Old 11-08-2013, 03:46 PM
numbers sound very close to me from what i have read in the past
post #7 of 9 Old 11-23-2013, 07:12 PM
GET A 73 *****ES
sean andreano is offline
post #8 of 9 Old 11-24-2013, 06:03 AM
I have a 6.4 and 2 "73"s and they do the same thing Sean it's not a bad thing it's just warming the engine
SCTREEGUY is offline
post #9 of 9 Old 12-11-2013, 08:15 AM
SD350's Avatar
I take it you live in a warm climate? lol
Its completely normal, makes the truck actually warm up when its -40 degrees F over night.
2008 F350 FX4 King Ranch CC SB
Spartan 275 and 210 Tow as main tunes, AFE CAI
+ Spartan =
SD350 is offline
