Vacuum pump - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-24-2013, 08:51 PM Thread Starter
NDF250KingRanch's Avatar
Vacuum pump
Hi, Hope someone can help. My 08 F250 SD's vacuum pump located on drivers side by the firewall it started to continully run. The tubing was cracked and falling apart. I've replaced one line from the a tee connection. The problem is this; it looks like there should be another line coming from the tee. What i'm looking for is a diagram of the vacuum lines so I mmake right. thanks
NDF250KingRanch is offline
