New Traction Bars, now lots of vibration while accelerating - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-22-2013, 05:22 PM Thread Starter
onebadmutha's Avatar
I just put a set of Pro-Comp Traction bars on my 2008 f-250 with an 8 inch lift and 38 inch tires. I immediately noticed a huge difference... in my steering wheel as it vibrates BAD under acceleration. It is noticeable at all speeds, then, you let off the throttle, and its gone. I unbolted and suspended the traction bars temporarily to ensure they were the culprit, they are. Why would they cause this vibration under acceleration?
onebadmutha is offline
post #2 of 9 Old 10-22-2013, 05:24 PM
Quoted: 762 Post(s)
Which ones did you buy?
Corey@CNCFAB is offline
post #3 of 9 Old 10-22-2013, 05:34 PM Thread Starter
The Pro Comp ones. IT just doesn't make sense to me how keeping my axle steady in one place finally, results in vibrations/shudders. The only thing I can think of is that the angle it holds them at is not ideal, but under acceleration, without traction bars, the axle would wrap backwards, producing a greater angle thus not making any sense. I understand the bars will transmit some road vibrations etc. to the cab, but this is pretty extreme vibration and ONLY under acceleration, hard or light.
post #4 of 9 Old 10-22-2013, 05:38 PM
Quoted: 762 Post(s)
Which ones from pro comp?
post #5 of 9 Old 10-22-2013, 05:45 PM Thread Starter
Sorry, here are the part #'s
Lateral Traction Bars
Part # EXP72400B
Traction Bar Mounting Kit
Part # EXP72099B
post #6 of 9 Old 10-22-2013, 05:48 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
just in to follow as i have been in the market for traction bars and just cant decide on a pair i just wanna see what the issue was/is.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 9 Old 10-22-2013, 06:03 PM
Quoted: 762 Post(s)
That's gonna be somewhat normal under hard acceleration by the pretty much ridgid 2 point connection bars. Its your axle trying to wrap but the energy has to go somewhere, so it bucks the traction bars back n forth as much as the urethane bushings will allow.
The best overall performing bars, no matter manufacturer, will be the 3 point connection with a shackle mount on the frame and an over/under mount on the axle. But....they are pricey.
post #8 of 9 Old 10-22-2013, 07:03 PM Thread Starter
I see many other users on here that are very happy with their pro comp bars. I feel like it can be made better somehow. The bolts do not line up perfectly, I had to use light to moderate pressure on a ratchet strap slide bolts through. Could this be loading the axle in some way? Has anyone tried a firm piece of rubber in between the frame and frame mount?
post #9 of 9 Old 10-22-2013, 07:07 PM
Quoted: 762 Post(s)
Bolts not lining up could definitely be an issue. That may be making yours buck more than normal.
