Killed the Truck, Kinda... - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-15-2013, 12:08 PM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
So since last Friday when I was delivering a cord of wood, around 5K gross weight, I've been hearing this kinda hissing of air, but louder, and was thinking it was an exhaust leak. I also noticed a bit of a loss in power, esp when towing the trailer, seemed to be sluggish going up grades and the EGTs were getting into the 1200s. So brought the truck to my mechanic today, he says its a torn flex pipe, on the back of the engine before the turbos, said I'm probably loosing close to half the exhaust, so therefore I'm loosing boost. I know the cab has to be pulled to do the job, and don't know how much time I have before it inevitably strands me somewhere.
I'm guessing that the hot tune on my livewire finally caught me. I knew something would happen, always thought it'd be the tranny though. I was really hoping I'd make it to the trade-in date, hoping I still will next week. Got appts to get the truck stripped down, just hoping the truck holds out.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #2 of 10 Old 10-15-2013, 05:39 PM
Here's my only concern.
Running too rich aka where is all that extra fuel going?
Less boost less oxygen to burn mean left over fuel.
But fuel might also be based on boost pressure so it might not be a big deal..
If not then just your exhaust breaking in half. Also wondering if the gases are finding away into your cab.
Have the cab removed replace the hpfp and upgrade to Rudy's and 4" down pipe. If you can bank it.
Sorry to hear..
GSchretter is offline
post #3 of 10 Old 10-15-2013, 09:08 PM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
Has nothing to do with the HPFP, plus that was replaced last year, it's practically brand new. When I saw my mechanic, he opened the hood, and had me mash the throttle, I saw a huge plume come up from the back of the engine, and nothing out the tailpipe. I was thinking it might be the up-pipe, because that did have a small crack in it 6 or 7 months ago.
Accufab Elbow
LineX in the Bed
post #4 of 10 Old 10-16-2013, 07:14 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yup sounds like a cracked up pipe. My truck is in the shop getting 6.0 manifolds and Rudy's up pipes. That's probably the best option but not worth it if you are trading it in. What are you trading it for?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 10 Old 10-16-2013, 11:16 AM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
Pretty much a straight up trade on the same truck just a 14, also a long bed.
Accufab Elbow
LineX in the Bed
post #6 of 10 Old 10-16-2013, 02:58 PM
What dealership is that!
SCTREEGUY is offline
post #7 of 10 Old 10-16-2013, 05:45 PM
BlackSheep5's Avatar
You don't have to pull the cab to do up pipes.
Sent from AutoGuide.com App
08 F250 6.4L FX4
BlackSheep5 is offline
post #8 of 10 Old 10-16-2013, 08:03 PM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
True, you don't have to, but it makes it easier.
Accufab Elbow
LineX in the Bed
post #9 of 10 Old 10-28-2013, 02:52 PM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
Ok, so I looked at the truck closer today, and I don't think it's the actual pipe, it's some type of flex joint/pipe that connects the pipes.
Accufab Elbow
LineX in the Bed
post #10 of 10 Old 10-28-2013, 02:54 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
So one of the bellows is leaking? Do you have a pic?
08 F350 cc/sb 4X4
