Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum
Old 06-21-2008, 01:52 PM
MDow MDow is offline
95 mph code????
Hey all,
I had the Check engine light go off last week and took it to the dealer and they said it was a code saying I went 95 MPH of over. They said if there is a problem with the engine it would not be cover due to misuse. Has anyone ever heard such a thing?
Old 06-22-2008, 01:27 PM
Dusten Dusten is offline
Send a message via MSN to Dusten
if you hit the speed limiter, it stores a code. however it wont throw a CEL.
Old 06-22-2008, 02:06 PM
The cel was for one of the probes in the exhaust. Not sure what one, will find out when I get the truck on Tuesday.
Old 06-23-2008, 12:49 AM
DavidPhillips DavidPhillips is offline
So let me get this straight. The truck has a limiter at 95 mph. If you go over 95 mph it voids the warranty. That's sounds like BS to me. How much over 95 did you go?
Old 06-23-2008, 03:29 AM
you cant go over it, you run into it
the truck stores a code. think of it this way, if you tossed a rod out the block, and they pull a code that sh ows at the same you, you had the throttle pinned, doing almost 100, they are really going to warranty anything?
Old 06-23-2008, 05:33 AM
A8050266 A8050266 is offline
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
Not that anyone should be going over 95....
BUT Is their anyplace one can go without breaking some rulez!!! geez.
GD lawyers!
Snowman_175 Snowman_175 is offline
I have had the code many times stores in the PCM but no CEL. The Exhaust has thrown a couple of CEL in teh recent past.
Old 06-23-2008, 08:19 AM
HaHaHa, I'd like to see them try to refuse warranty for that. The 95 mph limit is the safe speed of the tires. The rpm at 95 is nowhere near maxed out.
Old 06-23-2008, 05:45 PM
Well thats part of the problem...I never went that fast. The GPS in my truck says the fastest I have gone was 86. Not that they asked for proof, I showed them the GPS. At this time they are not refusing anything.
Matt
Old 07-21-2008, 10:21 PM
JMart JMart is offline
Powerstroken Locksmith
Wonder what exactly Ford Tough is? Its built Ford Tough but cant go 95 mph?
