2008 6.4 no crank HELP PLEASE! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-23-2013, 12:35 PM Thread Starter
amsoil929's Avatar
I have a no start issue with my 2008 6.4 F350 4x4 srw. Found this thread :http://www.justanswer.com/ford/2hbbn...el-having.html
The diagram showing the black plug to disconnect and run a jumper, did that. Got the truck to crank but will not start. Only cranks with the jump wire connected. Will not crank with key. And again, it will crank continuously but will not start.
Bought the truck with just over 100,000. Has about 120,000. To my knowledge: no dpf delete no tune
Please help!!!
-Rick
amsoil929 is offline
post #2 of 5 Old 09-28-2013, 09:12 AM
Do you have access to a scan tool? Could be a couple things most likely it's one of the egt sensors wacked out. If the computer thinks the truck is too hot it will cause a no crank, pretty common. It also could be the GPCM is shorted out.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #3 of 5 Old 09-28-2013, 09:14 AM Thread Starter
amsoil929's Avatar
Thank you for the reply.
Took it to the dealership, fuel pump safety switch.... Dumb!
post #4 of 5 Old 09-28-2013, 09:20 AM
Yup, that was my next guess... Glad you got er fixed!!
Friz186 is offline
post #5 of 5 Old 09-28-2013, 09:21 AM Thread Starter
amsoil929's Avatar
