White smoke at random - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-15-2013, 06:26 PM Thread Starter
Jerzyperson's Avatar
So whine driving at random. Doesn't do it often, usually right before, or at re beginning of regen. It will smoke. White smoke. Kinda like a gasser when it's cold out. But it does it at all temps but only does it for 30-45 seconds then stops. Truck hasn't been deleted yet. Still bone stock. What's going on?
Jerzyperson is offline
post #2 of 14 Old 09-15-2013, 11:13 PM Thread Starter
Bunp
post #3 of 14 Old 09-16-2013, 10:26 AM Thread Starter
Bump
post #4 of 14 Old 09-16-2013, 12:00 PM
Mine does that in regen but only when engine isn't up to temp.
Austin351 is offline
post #5 of 14 Old 09-16-2013, 01:32 PM Thread Starter
Mine does it using during regen, but usually after it sits at idle
post #6 of 14 Old 09-20-2013, 09:44 AM
Mine does the same thing all the time. Could be driving down the interstate and sporadically does it. Only for about a mile or so then stops. Looks like nobody else has an answer to it either.
Columbus Archer is offline
post #7 of 14 Old 09-20-2013, 10:12 AM Thread Starter
Mine is exactly what yours does. And apparently not
post #8 of 14 Old 09-21-2013, 05:54 AM
Chungo's Avatar
My truck is tuned but had the same problem with intermittent white smoke. Turned out it was a hole in my inter cooler that would allow H2O to build up and under hard acceleration (merging) I would spew white smoke for a few seconds. Dunno but might help?
Sent from AutoGuide.com App
Chungo is offline
post #9 of 14 Old 09-21-2013, 12:48 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
There is a tsb for white smoke involving the cac. Ill try and find it
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #10 of 14 Old 09-21-2013, 02:50 PM
TD-5's Avatar
Quoted: 3 Post(s)
Most of these trucks smoke to some degree when the regeneration first starts because the fuel is being injected late after TDC and the system has not built enough heat to fully ignite the diesel fuel that is being added to burn out the soot from the particulate filter. The "White" smoke is from cold incomplete combustion of the diesel fuel which condensates after being compressed but hasn't burned. If you stand by an exhaust pipe when its belching condensated diesel "white smoke" it will make your eyes water & smells very acrid. This is in contrast to steam exiting an exhaust pipe from a coolant leak which disapates quickly,& may smell a little like antifreeze but thats about it.
TD-5 is offline
