way to drop cooent temp - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-12-2013, 03:08 AM Thread Starter
up here in Canada we have lots of hills towing my trailer my coolent temps get alittle hot sometimes is there anything out there to help keep it cooler
rogco is offline
post #2 of 8 Old 09-13-2013, 03:00 AM
there is no real room for a secondary fan with all of the coolers that are on the front of these rigs. the only thing i know is to change the fluid regularly and use the ford coolant because it has anti-cavataion properties to it which helps our trucks out greatly.
kmack08 is offline
post #3 of 8 Old 09-13-2013, 04:55 AM
superduty6.4's Avatar
What are your temps when towing?
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 8 Old 09-13-2013, 08:14 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea what do you consider hot? At about 220* the engine fan should come on and cool thing off.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 8 Old 09-13-2013, 08:49 AM Thread Starter
My defuel is swt at 220. And 2 hills that I pull often it sees 230
rogco is offline
post #6 of 8 Old 09-13-2013, 08:53 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Does the 6.4 have the same type of fan set up at the 6.0?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 8 Old 09-13-2013, 09:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Did the fan come on?
08 F350 cc/sb 4X4
post #8 of 8 Old 09-13-2013, 09:04 AM Thread Starter
Yea turned on at 225.
rogco is offline
