rough idle but runs fine - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-09-2013, 05:15 AM Thread Starter
Last night i developed a rough idle. I had thrown a low contribution on cycl 1 and high fuel rail pressure codes but they went away. Truck drives fine and the miss goes away once the idle is cracked. Where is the best place to get a replacement injector and is this the right place to start. Im not moving the truck unti i do some major diagnosis and starting with injector replacement.
TimH is offline
post #2 of 2 Old 09-09-2013, 06:48 PM Thread Starter
Checked tonight and have alot of blow by when cold. If you take the cap off and just set it in there it dances but has alot of smoke. Is this normal when cold as things should expand?
TimH is offline
