6.4 Squeak/Chirp - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-03-2013, 07:26 AM Thread Starter
0864stroker's Avatar
6.4 Squeak/Chirp
I have a metallic like squeak/rattle/chirp (don't know how to exactly describe it) coming from my truck after sitting for 2 weeks. When I parked the truck no noise what so ever, start it up and ever since I have had this sound. The sound seems to quiet down after it gets to oper temp. you can hear the sound better from the driver's side wheel well and underneath, possibly near the egr cooler. The sound seems to rise with rpms. Truck runs like normal just kind of worried about what it could be.
Video of the sound:
YouTube
'08 F-250 Lariat
SCSB 4X4
BF Goodrich Rugged Terrain T/A
H&S Mini Maxx
Flo-Pro 5" DP Back
20% Window Tint
Recon Smoked Cab & Mirror Lenses
0864stroker is offline
post #2 of 10 Old 09-03-2013, 11:54 AM
Tensioners? Belts? I'd start there.
Expirobo is offline
post #3 of 10 Old 09-03-2013, 04:34 PM
matted2thefloor's Avatar
I've done a lot of research on this too. Mine has a metallic-like chirp noise heard mainly at idle. Checked the belts and tensioners and all looked to have been replaced not too long ago...maybe chasing this noise! Sometimes I hear it more than others so I was hearing it yesterday and I got underneath with it running and the noise is most prevalent at the rear of the engine...I'm thinking the flywheel is cracked, but through my research I haven't seen many instances of a cracked flywheel. I know it's nothing internal because I just got back a favorable BlackStone report and the noise has been there since I bought it back in June.
I'm going to be taking a job at the local Ford dealer soon, so maybe I'll get to check into it...
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #4 of 10 Old 09-04-2013, 05:35 PM
Quoted: 5 Post(s)
Send a message via AIM to PSDfreak
Pour a very small amount of water on the belt while its running... If the noise goes away for a moment it is likely the belt. If not you can try spraying a bit on the tensioner/idler pulleys one at a time and see when it stops... That'll be your culprit
Sent from AutoGuide.com App
'97 F-250 PSD, 4x4, ZF-5...Few Doo Dads
Tuned by TW -
-- SOLD
'09 F-250 6.4L, FX4, CCLB, 4" Pure Performance 4-Link Suspension Lift, 325/60/20 Goodyear Duratracs -- SOLD
'14 F-350 6.7L, Lariat, CCLB
RED 31
PSDfreak is offline
post #5 of 10 Old 09-05-2013, 03:29 PM
Tried all that already...first thing I did. Didn't phase it a bit!
post #6 of 10 Old 09-07-2013, 06:15 AM
Chirp
I had the same noise, the belts looked good and no slack or movement on tensioner, decided to get a set of Gates idlers and tensioner with a new belt, chirp gone...it was a gamble but paid off. Seems to be common on the 6.4
Hopefully it is not a scored rocker chirp ....SMMastertech on youtube has a video on it search 6.4 chirp...its there.
Let us know how it works out
toddster is offline
post #7 of 10 Old 09-07-2013, 12:14 PM
I saw that video when I first started researching. That noise he described as ONLY evident AFTER reaching operating temps. Mine will do it COLD, HOT...as soon as started or sometimes not until it's been run a while. Quite irregular at best.
Where did you source the Gates brand pulleys and belts from? Did you do both tensioners too?
post #8 of 10 Old 09-07-2013, 05:18 PM
local parts store had them in stock, they said they were a common seller, only did the alternator belt-tensioner and 2 idler pullies, seems to be the common ones to go, a/c is less common. most videos call for schroud removal, I did it by moving the CAC pipe = much easier and no time at all.. was a cheaper bet than opening engine, worked for me ,,,have 95k miles and pretty sure they were never changed although looked brand new,
I can describe how to do it if you like....1 hour including beer or coffee break
oreiley's carries them too
toddster is offline
post #9 of 10 Old 09-08-2013, 01:13 PM
Thanks for the info... I haven't heard the noise in a few days now. I'm more concerned about the lower radiator hose leak. Will be taking care of that issue first!
If I get in a jam with the pulleys and such, I'll hit ya up!
post #10 of 10 Old 09-12-2013, 04:40 AM Thread Starter
Been busy and havn't checked in in a while. Like matted2thefloor said, my belts and tensioners look fine and water didnt change a thing. As far as the rocker arm issue as toddster mentioned, he stated it starts when the truck gets to operating temps.
My truck ONLY does it when it is first started and for maybe 3-4 mins or until my temps get around 130-160. Once they reach that temp, the sound completely disappears and does not reappear until it is parked for a few hours and the temps cooled down a lil. Upon restart it is there until the temps rise again.
I would think if it was the belts or rocker arm it would do it more than just til my temps rise. I'm hoping it is nothing major, but I spoke with a Ford mechanic I am friends with and he said it was normal per the TSB, drive it and don't worry about it. That's hard to do and also annoying.
'08 F-250 Lariat
SCSB 4X4
H&S Mini Maxx
Flo-Pro 5" DP Back
20% Window Tint
