08 f350 hvac blower - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-31-2013, 04:48 PM Thread Starter
08 f350 hvac blower
Hi guys. Hoping you can help. I live in Saskatchewan , Canada, and recently went on a weekend trip to alberta. we had the ac pumping hard all weekend, it was around 32 celcius most days, damn hot. anyway last day there noticed the fan wasn't blowing air anymore. I replaced some fuses and relays and checked the others associated with this and they are all fine. the defroster gave off enough warm air to defog my windshield and at highway speeds you can feel the ac a little. basically cold and hot both work as well as the direction of flow. just no blowing of the fan even on full power. I have the dual auto climate control. im thinking of ordering a blower motor but maybe its something else? my sct said code u0164 lost communication with hvac control module. but that may mean squat. anyways any ideas guys???
nocturnal30 is offline
post #2 of 15 Old 09-07-2013, 07:22 AM
If you cannot work it on high, it is not the resistance, check for 12 volts at the fan motor, if it is present, most probably a new motor is needed.
Good luck
toddster is offline
post #3 of 15 Old 09-07-2013, 11:10 AM Thread Starter
ok. when it stops raining outside ill check it out and get back to you. ya I move the fan control down or all the way up and the little bars move on the display but makes no difference, no fan at all. thanks for the reply , appreciate it.
post #4 of 15 Old 10-13-2013, 12:42 PM Thread Starter
well the fan doesn't work period. I actually changed relative fuses as far as I know anyhow. bit the bullet and bought new blower fan.I have the dual climate control and turned fan on full etc. don't see 12volt at connection.wtf? even plugged brand new fan into connection. guess what? doesn't work. now what? this truck is starting to piss me off. I drive a 96 caprice with 710000 km on it and everything works fine
post #5 of 15 Old 11-17-2013, 10:03 AM Thread Starter
one thing I remember when we were on holidays. when it quit working, I pulled the fuse for head control 10 amp. and it seemed to start working again for awhile when I put it back in. then quit again next day and hasn't worked since. fuse wasn't blown though. maybe head unit for hvac controls is shot? thing is everything does what it should except the blower fan
post #6 of 15 Old 11-17-2013, 10:31 AM
Powerstroke Techie
To me it likely needs a blower fan speed controller if you have the electronic HVAC instead of the twisty knobs version.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #7 of 15 Old 11-17-2013, 12:52 PM Thread Starter
thanks. but what is that and where is it?
post #8 of 15 Old 11-17-2013, 12:53 PM Thread Starter
ya it is the electronic type too. forgot to mention that. no fan and snowing out here already and cold. barely see out my windows. basically got to get this fixed before I can winter drive it
post #9 of 15 Old 11-17-2013, 12:55 PM Thread Starter
oh and I was using my sct as a scanner one day and it had a code that said something about no power to blower fan or voltage or something like that. sold the tuner now
post #10 of 15 Old 11-17-2013, 01:00 PM Thread Starter
code u0164 . lost communication with hvac control module. what does that mean? that was the code stored in the sct device
