CODE P0194 HELP. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-28-2013, 03:50 PM Thread Starter
TxBoyJay's 08 KR250's Avatar
CODE P0194 HELP.
recently took my truck to the dealer to get some things done, and this code popped back up a day after i got it back. so i took it back in to talk to em, and they said they could only reset my pcm but if they did that the truck might run like sh*t and or not run at all since my dpf is deleted and is clearly in OFF mode. they said since my dpf delete is just a piece of pipe welded in and my sensor just hangs there, their test read "no back pressure" since the sensors isnt hooked in, i was told thats why im getting this CEL, and that i needed to put in a resistor to connect to the sensor to tell the computer to read normal.
who else has had this prob?? i need some feedback and info PLEASEEEEEE...
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
post #2 of 6 Old 08-29-2013, 12:09 PM
What tuner are you using? Or did you have the PCM programmed to turn off the DPF instead of using a tuner?
B. Adams is offline
post #3 of 6 Old 08-29-2013, 01:54 PM Thread Starter
not sure. when i bought the truck it already had the dfp delete. and my buddy hooked up his edge just to show me that the DFP was turned off.
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #4 of 6 Old 08-29-2013, 01:56 PM Thread Starter
i'm going to probably use the SCT livewire ts #5015
and hopefully it'll work good with the dfp delete.
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
post #5 of 6 Old 08-29-2013, 05:27 PM
Just make sure you get one that's capable of deleting the DPF, I think that's 5015R (Race version). I don't think the normal 5015 will work for you. I know SCT had some issues with the EPA a while back and paid a huge fine and had to quit making race tuners. I think you can still load third party tunes on an SCT to do the deletes, but that'll cost you a little more.
Be sure you know what you're buying.
B. Adams is offline
post #6 of 6 Old 08-30-2013, 04:19 AM Thread Starter
damn now thta you mentioned that, i went to look up a little more and i think your right. well i was already planning on a third party tune, just not at the same time of purchasing my tuner, but i guess i'l have to do so now.
Bully Dog CAI
5k HID's
30in LED Light bar
4in TUFF LED Fogs
Find me
New DD^ 03 GT Vert
