Turbo going out? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-18-2013, 12:51 PM Thread Starter
Jerzyperson's Avatar
Turbo going out?
I have a 2008 6.4 that I've owned for maybe 3 weeks. Well I started to notice a squeal in the mornings, only when the turbo spooled. Well lately it will still squeal but there's also a loud wooshing sound. Sounds like the fan, but doesn't change sounds even the truck shifts or anything. The more boost, the list the wooshing. I'd this my turbo going out? Wheel? Exhaust brake? What's going on. I'm fixing to get rid of the egr and dpf/cat. Could it be related to the egr? I'm new to 6.4 so I'm totally clueless.
Jerzyperson is offline
post #2 of 8 Old 08-18-2013, 02:07 PM Thread Starter
Louder with more boost. Autocorrect is killer
post #3 of 8 Old 08-19-2013, 08:19 PM Thread Starter
No help?
post #4 of 8 Old 08-19-2013, 08:45 PM
Finding a noise by text is hard to do..... could be fan clutch, either Turbo, etc. Use a stethoscope or a 3/8 ratchet extension to try and pinpoint the sound
Hauser is offline
post #5 of 8 Old 06-27-2014, 07:01 PM
F350Powerstroker's Avatar
Subscribed...I am having the same exact issue right now except on a 6.0...killing me can't pinpoint it!
~1973 F250 Highboy
~2003 F350 Super Duty XLT FX4 6.0 Powerstroke
4.56 Yukon Gears,Detroit Locker,37x13.5x17 Interco Super Swamper M16,8in Custom Lift,Bilstein 5125 Custom Valved Shocks (Triple Front/Dual Rear),Fabtech Dual Rear Shock Kit/Traction Bars,ARP Head Studs, Sinister Headers/Y Pipe/Regulated Return,175 cc Injectors,Edge Juice Platinum with Attitude,SCT Tunes,Snow Performance Stage 3 Water Methanol Injection,FASS 150/180,Banks Techni-cooler System,Fluidampr,4in Straight Pipes.
F350Powerstroker is offline
post #6 of 8 Old 06-27-2014, 07:41 PM Thread Starter
I found it as a leak in the exhaust manifold. Fixed it. Then the other blew off.
post #7 of 8 Old 06-27-2014, 11:14 PM
Really!? All that noise from exhaust manifolds! HELP! Turbo?Y Pipe? Air Filter Howling and Squeal? CAN'T FIGURE OUT!!! is the link for my problem I listed, let me know if I described what this issue. I think so and it would help me out a lot confirming! Thanks
~1973 F250 Highboy
post #8 of 8 Old 06-28-2014, 02:31 AM Thread Starter
Sounds like cracked up pipe or manifold. I broke two bolts on passenger side manifold and it sounded like that. Maybe three bolts would allow enough air not to squeal at first. Thoroughly check the whole exhaust system
