DAMN EBP - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-02-2013, 08:09 PM Thread Starter
Skorchrock's Avatar
DAMN EBP
Truck keeps throwing that damn P2263 so I took off the EBP pipe and sensor to clean it out. The tub was clean and the sensor had a little build up but nothing bad. I've done my EGR deletes etc etc. w/ Spartan 310 tune. I have read that it could be related to turbo bearings and oil levels as well as the VGT not working. I've checked all that except for the bearings. WTF? I don't have leaking injectors and the head gaskets are good. Any idea?
Skorchrock is offline
post #2 of 9 Old 08-03-2013, 12:31 AM
srjd's Avatar
Quoted: 2 Post(s)
Mine throws that code every winter cause the tube freezes up then the vgt shuts down. Happened once in the summer too if change the ebp sensor even if it looks fine I bet that will fix it
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 9 Old 08-03-2013, 06:50 AM Thread Starter
Skorchrock's Avatar
That will be my next step after I do all the free checks. I don't know if the heat and 136K on it has anything to do but it's getting old. The performance isn't hindered one bit so I don't know.
post #4 of 9 Old 08-03-2013, 07:33 AM
You could always move the sensor and eliminate the tube.
Here's mine.
B. Adams is offline
post #5 of 9 Old 08-04-2013, 12:20 AM Thread Starter
Skorchrock's Avatar
Think I'll be doing that tomorrow. Did you have to replace the sensor? Or did you move it and it stopped throwing code?
post #6 of 9 Old 08-04-2013, 04:59 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
Here's a couple pics I did also. I guess there is a block off plate you can buy that already has the threads for the ESP sensor. I have never looked.
6.4L Up-pipe delete & EBP relocation
Big_Smokey is offline
post #7 of 9 Old 08-05-2013, 07:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Is the heat bad for the sensor? I thought the tube was there because its a pressure sensor and the sensor will get to hot? Just curious
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 9 Old 08-05-2013, 08:07 AM Thread Starter
Skorchrock's Avatar
Good question!
post #9 of 9 Old 08-05-2013, 08:15 AM
Without a DPF and EGR, the exhaust doesn't get nearly as hot as before. I'm guessing that's a factor.
I've had mine this way since about January with no issues as of yet.
B. Adams is offline
