Dash spazzing out. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-02-2013, 06:35 PM Thread Starter
Brysonperry's Avatar
Dash spazzing out.
My abs light came on about a week ago, now when the cruise is set on, the speedometer will go to zero and my mini maxx will go to zero and then the truck thinks its at zero and needs to get to where its set so it'll just shoot forward. Then all of a sudden it will work again for a while. The other gauges work to. So would a speed sensor or something screw up when the abs screwed up too or something?
Brysonperry is offline
post #2 of 2 Old 08-03-2013, 05:44 AM
Others have had spazzout issues with the mini maxx. Check that your hdmi cable isn't bad. Also, anytime you have a bad sensor, it is best to get that repaired. I haven't checked, but the ABS sensor may be part of the cruise control loop.
Expirobo is offline
