Ford Techs - need IDS help for IC module config - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-25-2013, 07:15 AM Thread Starter
Have a current IDS with current subscription. When I go into program the IC, I get to a configure the module screen that has "FFFF FFFF FFFF" across the top with a keypad underneath on the screen.
I have no idea what it is asking me for here, or where to find the code/number I need to enter there. Help?
I've never run into this before when programming a module - new or old.
ASE Master, L1, T2, Own some modded Cummins trucks and work on them all. I have a Ford IDS if you are near...
bluthndr is offline
post #2 of 2 Old 07-25-2013, 09:43 PM
It is asking you for as built data that you can only obtain through the Ford Professional Technician website that we at the dealership use.
If you PM me your VIN I can get it if you need it.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
