brakes smelling - piston cracked - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-21-2013, 06:56 PM Thread Starter
So I went to remove my rear brake passenger brake because it was smelling so bad. The piston had cracked and was forcing the brake pad against the rotor thus the reason for the burning brake smell.
Can I just replace the piston that I removed?
I can't find a part number anywhere.
Or do I have to replace the whole caliper assembly?
cor21e is offline
post #2 of 3 Old 07-22-2013, 03:04 AM
Yes you can just get the caliper it's self. You can visit sites such as rockauto.com to guide you on the part number information as there are several variations out there.
DisposableHero is offline
post #3 of 3 Old 07-25-2013, 09:24 AM
When you say, "piston that I removed", do you mean the physical piston in the caliper or the entire caliper? Problem is, if it over heated, it probably marred up the inside of the piston sleeve. I'd do the whole caliper. In fact, I'd do both since this is more common than Ford would admit.
Get some good aftermarket brake pads and turn your rotors if they need it. Flush the fluid too. If it got overheated enough to crack the piston, it probably baked your brake fluid. Once it's overheats, it breaks down and can accumulate moisture and lose it's viscosity.
My motto: If you only take care of two things on your vehicle, make sure it's the brakes and tires.
If anything else fails, you'll live. Losing brakes or a tire can become life threatening really quick.
Expirobo is offline
