Banging my head against my transfer case while laying on my creeper im so frustrated! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-04-2013, 02:59 PM Thread Starter
Crowellski's Avatar
So here is the scenario:
Purchased a 6.4 2008 F-250 3 wks ago. Wanted to start getting rid of some of the known problems. So i bought a H&S Mini Maxx with race tune unlock, 5" turbo back Flo Pro exhaust system.
First i mounted, installed tune, and did my race unlock. (with factory exhaust system still on). Truck ran fine. So far so good. I also tried running the truck without the sensor plugged in next since chances are they are rusted in. (which they are). Still started up no problem.
Next i take the old exhaust off and install the 5" Flo Pro system (race system) with bungs. (figure i can just plug them since i have been told by a service guy that the H&S can run without the sensors).
I get the new system fitted and hung nice and pretty, and for some reason i plugged the top sensor back in that went into the DPF (the one with the metal bracket and rubber hose) since i could get that one out of the old system.
Clean up my tools and jump in the truck and.......no start! I get out and unplug the one sensor figuring maybe for some freak reason it would cause it to no start, get back in and still nothing. Now i have an 8000lb windbreaker in my driveway.
Also, this is my first diesel, i am somewhat mechanically inclined (learning everyday). Any help would be greatly appreciated bc im broken and bloodied from this thing
Crowellski is offline
post #2 of 7 Old 07-04-2013, 05:34 PM
Powerstroke Techie
Won't crank or won't start?
If it won't crank... try the following:
ANNOUNCEMENT: EGT 13!
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 7 Old 07-04-2013, 05:39 PM Thread Starter
Crowellski's Avatar
It won't crank. All gauges and lights work but not even a click out of the starter.
post #4 of 7 Old 07-04-2013, 06:10 PM
Powerstroke Techie
Click the link in the above post.
MAKE SURE THE TRUCK IS IN PARK BEFORE BUMPING THE STARTER FROM UNDER THE HOOD!!
post #5 of 7 Old 07-04-2013, 07:57 PM Thread Starter
Crowellski's Avatar
We are leaving for the weekend so I will have to try when I get back. Once I get it started will it stay "fixed" or will I keep having this problem?
post #6 of 7 Old 07-06-2013, 02:17 PM
Powerstroke Techie
That's more of a diagnostic step then a fix.
If you've let it sit for the weekend it will likely crank. It is likely in a 60 minute lockout to prevent damage to the truck. It likely sees the sensor open circuit/over temp, and thinks the truck exhaust is overheating and is preventing you from cranking it to keep the truck from being damaged.
Make sure EGT13 (the last EGT sensor) is plugged in, and not damaged.
post #7 of 7 Old 07-08-2013, 06:19 PM Thread Starter
Crowellski's Avatar
It is running like a champ now! Thanks a million BAH! U have helped immensely!
