P1639 Fault Code - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By powercho
post #1 of 4 Old 06-30-2013, 01:06 PM Thread Starter
powercho's Avatar
P1639 Fault Code
Got this fault code yesterday before I started it. Check eng, battery, and ABS dash lights were illuminated, as well as the Traction Control. The code means the vehicle ID block is corrupt. I tried to clear it with the key in run and then with the engine running. Both didn't work... Truck runs fine and everything is in parameter.
Anybody run into this before? Hopefully H&S has a solution.
Thanks.
powercho is offline
post #2 of 4 Old 07-01-2013, 11:09 AM Thread Starter
powercho's Avatar
Fixed it. Called H&S and they walk you through the process. You have to talk to a tech support rep for an unlock code that changes every time you access.
They said a surge in voltage may have wiped out the information pertaining to the vehicle- model, wheel base, final gear ratio, etc. I was on hold longer than it took the time to update the Vehicle ID.
Going to have the alternator checked out.
Heavy_GD likes this.
powercho is offline
post #3 of 4 Old 09-27-2016, 12:52 PM
same issue can you explain how you fixed it?
Payin2play is offline
post #4 of 4 Old 09-28-2016, 11:49 AM
Quoted: 9 Post(s)
Just went through this myself....took truck to Ford and had them flash the PCM with as built data, and then reloaded tuner before truck was started.....took about 40 mins.
tofer is offline
