Running like crap - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-27-2013, 09:09 AM Thread Starter
Running like crap
So I have a 08 f350 6.4 it's all stock the problem is if it sits for a day or just driven its starts chugging or has no power. Once in awhile ill try getting on the hwy it lags starts blowing blue smoke if I get out of the pedal and back in it it's fine.im not what it is plus it seems to be going threw a lot of fuel more then usual I was poss egr clogged its still under warr but there's no engine light any help would be great thanks
Tow21 is offline
post #2 of 14 Old 06-27-2013, 10:35 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
possibly an EGR issue...
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #3 of 14 Old 06-27-2013, 09:32 PM Thread Starter
Is there a way to find for sure I know how the 6.0 is and how it comes apart but not sure with the 6.4
Tow21 is offline
post #4 of 14 Old 08-20-2013, 06:34 AM
flashover1969's Avatar
Send a message via Yahoo to flashover1969
Also check your map and iat2 sensor. Both are screwed into the intake manifold and are pretty easy to access. I was having a loss of power and lots of black smoke. I pulled these 2 out and both were just caked with layers of soot and oil. This is of course from the wonderful emissions crap. I used brake cleaner to clean em up. Truck runs way better afterwards and I have power back
flashover1969 is offline
post #5 of 14 Old 08-20-2013, 07:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ this and also clean the ebp sensor and tube. If that's clogged with soot the truck will run like crap.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 14 Old 08-20-2013, 07:53 AM
here is before and after pic if i can get the image to upload
After
post #7 of 14 Old 08-20-2013, 10:51 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
was the map sensor that nasty?
08 F350 cc/sb 4X4
post #8 of 14 Old 08-20-2013, 11:32 AM
No it wasn't as bad, but the hole for the sensor was partially plugged with the same sludge.
It's runs way better, but something is still "off" as it is still smoking more than usual. I've ordered a brand new MAP, which should be in today and I'm thinking about ordering a new EBP too. The tube and sensor weren't plugged, just were a bit sooty and I cleaned all that crap out too.
Another weird thing is the barometric reading on the truck is showing 13 psi and the absolute baro for the Phoenix, AZ area is 14.11. So I'm wondering if that's part of the problem too.
post #9 of 14 Old 08-20-2013, 01:12 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I'm not sure about the barometric reading but the new map sensor and ebp sensor should make a huge difference!
08 F350 cc/sb 4X4
post #10 of 14 Old 09-14-2013, 08:50 AM Thread Starter
Where on the engine is that sensor located ill check mine.the dealer cleaned and replaced the throttle body but its still acting up not as much
Tow21 is offline
