Wrench Light - P012F Code - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-26-2013, 06:04 PM Thread Starter
Ok brand new the diesel scene. I purchased a 2008 Ford F250 6.4L, and on my way home it threw up the wrench light. I had Autozone run the code and said it was P012F - coolant/oil issue. Nothing else appears to be wrong, it's not over heating etc. Truck has 128k on it, any ideas?
TxPlates is offline
post #2 of 14 Old 06-26-2013, 06:20 PM
Clogged oil cooler? I think, someone else should chime in.
Wmdpsd is offline
post #3 of 14 Old 06-26-2013, 06:33 PM Thread Starter
But if it were the oil cooler, wouldn't the truck be over heating?
TxPlates is offline
post #4 of 14 Old 06-27-2013, 03:40 AM
The water passages are known to clog in the oil cooler, that causes the oil to get to hot. I don't know if it will throw a code or not. Clogged oil coolers are common on these trucks.
Wmdpsd is offline
post #5 of 14 Old 06-27-2013, 06:28 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Do you have a way to check the difference between the ECT and EOT when the truck is at normal operating temperature?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 14 Old 06-27-2013, 02:51 PM Thread Starter
Well my wife dropped the truck off at Ford today or me, and they stated it's the oil cooler. Total repair cost $5053.41
I bought the truck Saturday, and drove off the lot with the premise that it was in working order. The repair invoice has been forwarded to them, and I'm awaiting to see if they're going to pay it. If not then looks like they'll have to send someone to come pick up their truck. I live in Texas, they're in Louisiana.
TxPlates is offline
post #7 of 14 Old 06-28-2013, 06:13 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That seems like a lot to put a new oil cooler in. Another option is the BPD oil cooler half kit and you could probably install it by yourself.
Bullet Proof Oil Cooler System, 2008-2010 F-Series, 6.4L Half-Kit
08 F350 cc/sb 4X4
post #8 of 14 Old 06-28-2013, 03:20 PM Thread Starter
Update - dealer I bought it from said they would tow it back to La, fix it and send it back to Tx. I don't trust them so I said no. But I did go to another shop in town that does performance diesel work that I've heard good things about, and they quoted me $2177 to do the work. Place I bought the truck from agreed to pay them to do it, so truck is in route being towed over there.
TxPlates is offline
post #9 of 14 Old 06-28-2013, 03:37 PM
Big_Smokey's Avatar
Quoted: 10 Post(s)
That's a better deal. For that id do an aftermarket setup though
Big_Smokey is offline
post #10 of 14 Old 06-28-2013, 04:15 PM Thread Starter
An a/m engine oil cooler? The OE isn't that pricy, are there a/m alternatives that are aroud the same price?
Also while they've got it all apart, should I have them do anything else maintenance wise? It has 129k on the ODO.
TxPlates is offline
