MAP sensor replacement help. Quick please! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-24-2013, 07:20 AM Thread Starter
I have an 08 F350 powerstroke and I know that the map sensor is bad. Just got a new one at the dealer and I'm ready to do the install. I'm a novice DIY'er and I'd like to know if I need to use any sort of thread tape or special grease when I put the new one in. Also, could someone tell me the correct socket size I need? I currently don't have my tools with me to check.
Any help is appreciated.
thedudebrah is offline
post #2 of 9 Old 06-24-2013, 07:57 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I replaced mine also. I don't remember the socket size but you need a deep socked because of the electrical connector. You do not need thread tape of grease. If you want you can put a little oil on the o ring before you install.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 9 Old 06-24-2013, 08:00 AM Thread Starter
Cool, sounds easy enough. Thanks for the quick reply. I was concerned I'd miss a small step or something.
post #4 of 9 Old 06-24-2013, 08:07 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem. Its an easy job. Good luck!
08 F350 cc/sb 4X4
post #5 of 9 Old 06-24-2013, 10:44 AM Thread Starter
Well that was easy. The hardest part was not burning my big hand. Fixed my issue!
And it's a 1" socket in case anyone else is wondering.
post #6 of 9 Old 06-24-2013, 11:14 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Good deal bud!
08 F350 cc/sb 4X4
post #7 of 9 Old 06-26-2013, 05:04 AM Thread Starter
I forgot to ask. Should I clear the code or will a drive cycle clear it automatically. It seems like after replacing the MAP, my fuel mileage dropped drastically (16 to 10 avg) and the dpf cleaned itself almost every time I drove the truck around town.
I don't have a code reader or programmer. Is there a key cycle to clear dtc codes? Google didn't help much.
post #8 of 9 Old 06-26-2013, 07:02 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I think you need a programmer to clear the dtc. I clear codes with the minimaxx. If the problem is taken care of it should clear the code after driving a few times. Also try cleaning the ebp sensor and tube.
08 F350 cc/sb 4X4
post #9 of 9 Old 06-26-2013, 07:23 AM Thread Starter
Alright thanks. I guess I'll just let it go through a drive cycle and see what happens. By the time I drove the 20 miles to work it was back up to 15 average. I'm in the process of saving up for a Spartan.
