Screech at low speed and heavy foot - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-22-2013, 05:32 PM Thread Starter
I have an 09 auto with 106,500 miles, dpf delete afe stage two intake. When I mash on it at lower speeds I get a screech coming from between the radio and air vent in front of the dash. It is not there when I am hooked to my box trailer. I run the 300hd tune/no power when I tow. When I am not towing, I run the 300 hd hot tune and that is when I get the noise. Had the cab off and replaced gaskets on up pipes at 99,000 miles. Any ideas?
Wmdpsd is offline
post #2 of 14 Old 06-26-2013, 02:22 PM
Probably sucked in a mouse and when you have the hot tune on, its butt gets burned...
Expirobo is offline
post #3 of 14 Old 06-26-2013, 06:06 PM Thread Starter
Could be that, or maybe my egr valve opening??? I really just learned that they my open to relieve excess boost?
Wmdpsd is offline
post #4 of 14 Old 06-26-2013, 09:30 PM
I'd suspect that or one/both of your turbos are crapping out.
Expirobo is offline
post #5 of 14 Old 06-27-2013, 04:35 AM Thread Starter
That's not good. When it put my intake on there was no oil in the intake tube, and no end play, egt are not out of control, makes good boost and good power. It only does it when it is cold. No sounds when I shut her off. There is no smoke
Wmdpsd is offline
post #6 of 14 Old 06-27-2013, 05:13 AM
Does it do it only while driving? Does it do it when you rev the engine in the driveway? Describing a noise to someone without a video is difficult to diagnose.could be something else?
Expirobo is offline
post #7 of 14 Old 06-28-2013, 01:50 PM Thread Starter
Yes it will do it when you rev it in the drive way. Only when it is cold. Not cold outside but cold for a motor. How do you post a video?
Wmdpsd is offline
post #8 of 14 Old 06-28-2013, 02:01 PM
JUGGS's Avatar
Serpentine belt slipping? Does it happen with AC on and off?
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #9 of 14 Old 06-28-2013, 02:08 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 14 Old 06-28-2013, 08:32 PM Thread Starter
You have to power brake to make the noise,when parked.have a video but won't upload from ipad? Just replaced both belts and tensioners in February.
Wmdpsd is offline
