Possible Exhaust Fix - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-06-2013, 07:40 AM Thread Starter
When driving home the other night an exhaust leak started suddenly while on the highway. I can feel where the air is coming from. It is the pipe that connects the drivers side manifold to the turbo. There is a small silver tube/pipe that comes into that exhaust pipe as well. It is leaking right around where the small silver pipe comes in. I still have most of my boost but only make around 18 lbs now according to the stock gauge versus the 25 I made before.
The real question is does the cab have to come off to fix this? Can I use some high temp JB weld and see if that holds? What do you guys recommend?
Thanks,
Rich
2008 Harley is offline
post #2 of 7 Old 06-06-2013, 11:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That is the up pipe and the silver tube is the back pressure sensor tube. It is possible cab on but most remove the cab to replace it. You can get a heavy duty up pipe from rudy's diesel or dark horse diesel to replace the factory up pipe.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 7 Old 06-06-2013, 11:30 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Or maybe this will work for you.
My 6.4 EBP sensor relocation
08 F350 cc/sb 4X4
post #4 of 7 Old 06-06-2013, 11:50 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
MIGHTY PUDDY!!!!
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 7 Old 06-06-2013, 12:01 PM
Fantom's Avatar
Quoted: 11 Post(s)
Feedback Score: 4 reviews
Originally Posted by Rammstein1224 View Post
MIGHTY PUDDY!!!!
Pat, don't be an idiot, that stuff doesn't work. You need this
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #6 of 7 Old 06-06-2013, 12:04 PM
Chapter Director
Quoted: 5 Post(s)
oh how could i be so damn stupid i used that to make my screen door boat last month
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 7 Old 06-15-2013, 07:11 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
ive been gearing up to do this as well. Only im going to relocate it like the b. adams did
just trying to figure out how to get my hands to undo the top two bolts
Big_Smokey is offline
