6.4 keeps dieing! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-04-2013, 06:29 PM Thread Starter
Angry 6.4 keeps dieing!
I have a 09 6.4 with 62k on it. has a spartan tuner and 4in dual exhaust and thats it. ill be driving along and the truck will just die and shut off, watch the fuel rail pressure just keep dropping till it shuts off. it isnt throwing any codes sometimes can turn the key a few times and itll start back up other times i have to reprogram it and itll fire right back up and drive fine. it happens every two weeks r so but one time it did it 6 times in one day and wouldnt restart. i put both fuel filters in it and it ran good untill today. spartan says they doubt its the programer so i dont kno what else it could be. lift pump? itll run great for a week r two then it happens again i cant even go on a long drive or a trip somewhere bcuz im scared it will die and not restart. i love the truck but really dissapointed in it shoulda kept my 7.3 any help is greatfully appriciated thanks!!
FTFstroker is offline
post #2 of 15 Old 06-04-2013, 07:23 PM
ADMIN AND TECH
SCUFFY828's Avatar
need to run a lift pump pressure test to see if the base fuel pressure stays at least or around 8lbs or so, if so then it may be the high pressure fuel pump,
im reaalyy curious why you are getting any codes ,it really should be leaving something in memory
ITS STOCK
SCUFFY828 is offline
post #3 of 15 Old 06-05-2013, 01:58 PM
a4t1rat's Avatar
Well I am interested also ..my truck does the same thing off and on. I have a H&S and if I reprogram it, it will restart also. I have been trying to figure mine out for about 4 months... mine seems to be cold related meaning when its warm out side say above 60 it happens less than say 40 outside. mine is a 08 dpf deleted and egr deleted. never any codes and all checks out ok on the snap on scanner..I will be watching this.
Injection is Nice but I'de rather be Blown
1941 Chevy Pro Street Blown BBC
1959, F-100 292 V-8 4Spd
1960 F-100 Factory 4x4
Freightliner FLD 120 Toterhome in the process Cat 3406
1977 Jag XJS 383 SBC
1991 F-350 2x4 Dually Blown 460
2000 Excursion 4x4 7.3 pipe, chip, ect.
SOLD..2004 F-350 4x4 6.0, CC, LB 8" lift 37" Toyo mt's and a few mods
2008 F450 4x4 6.4 Let the Fun Begin
Farm Toys...IH 856, 706, Hesston 6600
a4t1rat is offline
post #4 of 15 Old 06-06-2013, 10:02 AM Thread Starter
I tried putting an H&S in it last night did the same exact thing when it runs good the rail pressure at idel and WOT are good but when she's not running good I bearly have any I check wires filters everything and found nothing. Doing a pressure test on the lift pump tonight that's what I leaning towards I have an AirDogII on the way just incase ill let you know what I find
post #5 of 15 Old 06-06-2013, 01:00 PM
a4t1rat's Avatar
If it is like my truck you will find that the pressure is ok... I changed my lift pump just to be sure. The thing that always gets me is if its was the lift pump why will it start after you retune it? I talked to H&S and they said if the truck was shutting down due to a code such as a DPF code or ect, when you re tuned it, it would clear the code and start back up but I never had a code come up but kinda seemed possible ??? Keep us posted Oh and I keep my 7.3 so I drive it when the 6.4 is down
a4t1rat is offline
post #6 of 15 Old 06-06-2013, 02:08 PM
Quoted: 48 Post(s)
If you lose communication with a Mini Maxx while the truck is running, you'll lose your AC compressor and other things, and the truck won't restart until you reprogram it.
Kinda sounds like a wiring issue. Are the big wire bundles on the driver side fender area in good shape, not chafed, etc?
drunk on diesel is offline
post #7 of 15 Old 06-06-2013, 06:57 PM
a4t1rat's Avatar
That would be true but I don't have a mini Max on it.... I took it off for that reason its running the xrt pro now.
a4t1rat is offline
post #8 of 15 Old 06-06-2013, 08:32 PM Thread Starter
It has only threw codes once for the EGR low rail presssure injectors and some other stuff i cant remember which led me possibly to the HPFP if the wire chafe they will throw these codes but no fuses have blown and i have good rail pressure when it runs good. i will be doing the pressure test tomaro morning. the Air Dog II should be here to tomaro so hopefully thats the problem
post #9 of 15 Old 06-08-2013, 07:07 AM
Quoted: 48 Post(s)
My point is that if you get a brief communication interruption, it will cause similar issues, so I would be looking at wiring harness issues
post #10 of 15 Old 06-11-2013, 09:49 AM Thread Starter
Believe it was the lift pump. Put the air dog in runs great hasnt died no codes running like a champ....for now
