antifreeze barf out of rad cap - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-01-2013, 04:43 AM Thread Starter
so i recently bought a 08 6.4 with a DPF delete, EGR coolers still on, and with an H and S mini max running a HOT DAMN tune. Truck seems to cough antifreeze on Mild Tune setting out of radiator cap. Doesnt without the chip turned on. This is with normal driving.
Downloaded an update for the chip since it was way behind the times.
Im hoping this is the fix and im not looking at some headgaskets in my future. Anybody have a similar thing happen?
I FARM YOU EAT.
FORD/NEW HOLLAND TRACTORS
Poster is offline
post #2 of 16 Old 06-01-2013, 05:37 AM
superduty6.4's Avatar
You could try change out the degas bottle cap. Otherwise it a good possibility it's head gaskets.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 16 Old 06-01-2013, 07:10 AM Thread Starter
well, i did change out the cap and drove it around. Never leaked out of the cap with the no power setting set on my chip. Got reading about my chip, and the mild tune on my chip is 175 horse....which seems a bit excessive as well as the chip version being pretty obsolete. i think they have like 20 different versions past the version on my chip.
I FARM YOU EAT.
Poster is offline
post #4 of 16 Old 06-01-2013, 07:25 AM
The mild should be 125hp on the hd300 tunes. You could just dial it back to no power level. Thats 50hp. I would update if your version is way back.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #5 of 16 Old 06-01-2013, 07:26 AM
Where you running it pretty hard when it puked?
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #6 of 16 Old 06-01-2013, 07:33 AM Thread Starter
i got on it hard once or twice taking off on mild setting on a 45 minute drive of state highway driving with a little interstate driving mixed in.
so the no power setting is still 50 hp extra over stock? i figured no would mean no.
I FARM YOU EAT.
Poster is offline
post #7 of 16 Old 06-01-2013, 07:38 AM
If you were to switch to the mild tunes the power levels are 0hp, 80hp, 160hp & 250hp. The hd300 are 50hp, 125hp, 225hp, 300hp. The easy tunes are 0, 40, 80 & 160 I believe but they function the egr. I would bet that since it happened when you were going hard with it that it's the gaskets.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #8 of 16 Old 06-01-2013, 08:06 AM Thread Starter
i just dont understand this engine i dont guess. how can a head gasket be blown and the truck still run fine? If a gasket goes on any other engine, you lose power, blow white smoke, have water in oil, etc.
I FARM YOU EAT.
Poster is offline
post #9 of 16 Old 06-01-2013, 08:30 AM
The gasket only lets go under higher boost situations and in some cases people go many miles with blown gaskets. Some people get really lucky and just run a low hp tune until they can get it fixed up. I don't know how to explain the mechanics of it but maybe someone else will shed some info to help clarify.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #10 of 16 Old 06-01-2013, 02:11 PM Thread Starter
Well thanks for all your help. I just got this truck from a local dealer under the understanding that it was fixed and the mechanic there kept replacing the venturi valve and they said he would do fine with it but one salesman would drive it and the thing would leak. that got me thinking that the salesman was turning up the tune. I drove it all day today and it didnt leak.
i have noticed the radiator is leaking a tad. why you would put a plastic to metal radiator in a diesel application is beyond me. the vibration is probably destroying those things.
anyways im taking it back to the dealer on monday...im sure he will love the blown headgaskets idea .... how do you check for this on these engines so i know before the dealer mechanic tries to blow smoke up my ***?
one more thing, i have the exhaust delete, but i noticed those cooler things(egrs?) are still on the motor, is there any way that those could be making it puke? those are a lot cheaper to delete than to fix headgaskets.
oh and btw thanks for all the help. i work on tractors and such but this ford (international)engine is ridiculous. ha
I FARM YOU EAT.
Poster is offline
